Inter-vlan routing help
Bell-ah
I can't ping my directly connected router from my switch and I can't figure out why. I'm just learning how to do all this stuff so please have mercy on me. This is in packet tracer btw. Here are my configs:
Switch 1:
Current configuration : 2623 bytes
version 15.0
no service timestamps log datetime msec
no service timestamps debug datetime msec
service password-encryption
hostname S1
enable secret 5 $1$mERr$9cTjUIEqNGurQiFU.ZeCi1
no ip domain-lookup
spanning-tree mode pvst
interface FastEthernet0/1
switchport mode access
shutdown
interface FastEthernet0/2
switchport access vlan 10
shutdown
interface FastEthernet0/3
shutdown
interface FastEthernet0/4
shutdown
interface FastEthernet0/5
switchport trunk native vlan 10
switchport mode trunk
interface FastEthernet0/6
switchport port-security mac-address sticky
interface FastEthernet0/7
shutdown
interface FastEthernet0/8
shutdown
interface FastEthernet0/9
shutdown
interface FastEthernet0/10
shutdown
interface FastEthernet0/11
shutdown
interface FastEthernet0/12
shutdown
interface FastEthernet0/13
switchport access vlan 30
shutdown
interface FastEthernet0/14
shutdown
interface FastEthernet0/15
shutdown
interface FastEthernet0/16
shutdown
interface FastEthernet0/17
shutdown
interface FastEthernet0/18
shutdown
interface FastEthernet0/19
shutdown
interface FastEthernet0/20
shutdown
interface FastEthernet0/21
shutdown
interface FastEthernet0/22
shutdown
interface FastEthernet0/23
shutdown
interface FastEthernet0/24
shutdown
interface GigabitEthernet0/1
shutdown
interface GigabitEthernet0/2
shutdown
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 192.168.10.11 255.255.255.0
line con 0
logging synchronous
line vty 0 4
login
line vty 5 15
login
end
Router 1:
Current configuration : 1562 bytes
version 15.1
hostname R1
ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX1524F966-
no ip domain-lookup
interface Loopback0
ip address 192.168.20.1 255.255.255.0
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
ipv6 address FC00::1/64
interface GigabitEthernet0/0.10
encapsulation dot1Q 10
ip address 10.3.3.1 255.255.255.0
interface GigabitEthernet0/0.30
encapsulation dot1Q 30
no ip address
no ip address
duplex auto
speed auto
ipv6 address 2001:DB8:ACAD:A::/64 eui-64
interface GigabitEthernet0/1.10
ip address 192.168.10.1 255.255.255.0
interface GigabitEthernet0/1.30
no ip address
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1
log-adjacency-changes
network 10.3.3.0 0.0.0.255 area 0
network 192.168.20.0 0.0.0.255 area 0
network 192.168.10.0 0.0.0.255 area 0
network 192.168.30.0 0.0.0.255 area 0
network 209.165.201.0 0.0.0.255 area 0
ip classless
ip flow-export version 9
line con 0
logging synchronous
line aux 0
line vty 0 4
password 7 0822404F1A0A
logging synchronous
login
line vty 5 15
logging synchronous
login
end
Any help is much appreciated! Thank you!
7 Replies 7
on the switch, add:
ip default-gateway 192.168.10.1
Jon Marshall
Is the router connected to the switch on fa0/5 ?
If so you cannot make the native vlan 10 as the router is expecting to see a tag so you need to change the native vlan to just an unused one.
Jon
Martin L
zip your PT file and add it here;
Richard Burts
There are some things about this environment that we do not know and which might make some difference. For example the router to switch interface is on which interface. And which device is doing the ping to test connectivity?
The suggestion to add ip default-gateway is probably a good suggestion. But I suspect that this is not the issue - and it would really only be an issue if the switch were attempting to ping an address in a remote subnet. Which does not seem to be the case in the original post.
I believe that @Jon Marshall has correctly identified the issue. The switch config makes vlan 10 the native vlan. So frames from vlan 10 to the router will not be tagged. But the router configuration of the G0/1.10 expects frames on vlan 10 to be tagged. This mismatch would certainly make it impossible for the switch to ping the router.
The solution might be for the switch to make the native vlan something other than 10 (which is the solution suggested by Jon) or it would be for the router to identify vlan 10 as the native vlan in its interface config. Either approach should work.
Rick
Bell-ah
This is the actual packet tracer file itself. I'll try your suggestions out tonight, but in case anyone still wanted it here it is. Thanks for all your help!!
Both PCs IP configs are not correct;  What do you need to reach remote networks like this site? (hint: ipconfig /all)
if you change Native vlan from 1 to 10 on switch, you also must do this on router as well; or keep native as vlan 1; right now router's native vlan is 1 and that is on the main interface itself.  Router 3 is missing ip config on .30 sub-interface;
Router to router links do not need encapsulation dot1Q usually; aka, p2p links, no trunking. Basically trunking and vlans usually stay locally, do not cross WAN links, like vlan 10 on left side is not same as vlan 10 right side;  aka 2 different vlans even if u make/force them to share same subnet.
Try solve it by yourself; if u still need help, i can post my solutions later
Regards, ML
**Please Rate All Helpful Responses **
We need the enable password for the routers and switches in order to work with the Packet Tracer file
