Dual Wan 2 ISPs
mohamed.saber1
I've configured a router cisco 1921 for one ISP and works with different nat rules(for VoIP), now I've tried to add a 2nd ISP with failover without losing nat rules that I've configured in the 1st ISP interface. The problem is when I used a basic dual wan and failover configuration, internet works with the 1st ISP but lost the nat rules(VoIP not working) and also dual wan/failover not working. Here is the configuration:
(I've used Vlan2 for the 2nd ISP because I couldn't enter an @ip directly for the extension ports, I've got the error " ip addresses may not be configured on l2 links ")
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description ## MY LAN ##
 ip address 172.16.1.1 255.255.0.0
 ip helper-address 172.16.1.50
 ip nat inside
 ip virtual-reassembly in
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/1
 description ## IPS1 FIBRE ##
 ip address 83.XX.XX.61 255.255.255.254
 ip access-group MY_WAN in
 ip nat outside
 duplex auto
 speed auto
interface GigabitEthernet0/0/0
 description ## IPS2 FREEBOX ##
 switchport access vlan 2
 no ip address
interface GigabitEthernet0/0/1
 no ip address
 shutdown
interface GigabitEthernet0/0/2
 no ip address
 shutdown
interface GigabitEthernet0/0/3
 no ip address
 shutdown
interface Vlan1
 no ip address
 shutdown
interface Vlan2
 ip address 192.168.1.2 255.255.255.0
 ip nat outside
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip nat inside source list 100 interface GigabitEthernet0/1 overload
ip nat inside source list MY_LAN interface GigabitEthernet0/1 overload
ip nat inside source route-map isp1 interface GigabitEthernet0/1 overload
ip nat inside source route-map isp2 interface Vlan2 overload
ip route 0.0.0.0 0.0.0.0 83.XX.XX.60
ip route 0.0.0.0 0.0.0.0 78.XX.XX.69
ip access-list standard MY_LAN
 permit 172.16.0.0 0.0.255.255
ip access-list extended MY_WAN
 permit tcp any any established
 deny   tcp any any
 permit ip any any
route-map isp2 permit 10
 match ip address 100
 match interface GigabitEthernet0/0/0 Vlan2
route-map isp1 permit 10
 match interface GigabitEthernet0/1
snmp-server community public RO
access-list 100 remark portfwd
access-list 100 remark CCP_ACL Category=2
access-list 100 remark sip
access-list 100 permit udp any host 172.16.1.50 range 5060 5062
access-list 100 remark sip1
access-list 100 permit udp any host 172.16.1.50 range 8060 8061
access-list 100 remark keyyo
access-list 100 permit udp any host 172.16.1.50 range 16384 16482
access-list 100 remark OVH
access-list 100 permit udp any host 172.16.1.50 range 30000 40000
access-list 100 remark ovh1
access-list 100 permit udp any host 172.16.1.50 range 2424 2427
access-list 100 remark HTTP
access-list 100 permit tcp any host 172.16.5.150 eq www
My 2nd ISP Freebox settings:
IP address: 78.XX.XX.69
Private IP address: 192.168.1.1
Thanks!
devils_advocate
Level 7
Level 7
When you mention VOIP, is this a SIP provider on the internet somewhere?
SIP struggles with NAT by default so that could be why it works fine with the provider which gives you a Public IP straight to your Router and not with the ISP which providers a Private IP to the router.
Although the L3 header on the SIP packets will NAT and Route fine, the SIP payload address may be wrong once it gets to the SIP provider.
I have an internal ipbx server for VoIP, the problem as I mentioned is that with one ISP everything works fine but when I add dual wan/failover when I lose NAT rules (access-list 100) and aslo dual wan not working.
Now it's OK for NAT rules I just did a reload and VoIP seems working, but Dual Wan/failover still not. I followed cisco basic configuration for it: http://docwiki.cisco.com/wiki/NAT_failover_with_DUAL_ISP_on_a_router_Configuration_Example
Thanks again,
mohamed.saber1
Seriously guys no one knows how to configure a dual wan :/
Plz help :D
