Dual WAN does not pass on my CISCO router 2911
MUKADI Pierre
Hi there
I try to configure it to have dual wan but it does not work (I'm using the NAT Overload for both). 1WAN is blocked qnd can pass only if I deactivate the first overload, Here is my configuration :
MainFS(config-line)#do sho run
Building configuration...
Current configuration : 3629 bytes
! Last configuration change at 14:02:58 UTC Thu Jan 30 2014
version 15.1
service password-encryption
hostname MainFS
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 4 **********************************************************
enable password 7 ******************************************************
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip wccp web-cache password 7 *************************************
license udi pid CISCO2911/K9 sn FGL164710QK
track 10 interface GigabitEthernet0/1 ip routing
delay down 10 up 10
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description "WAN1 MICRO"
ip address 10.0.7.15 255.255.255.128
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
description "WAN2 MAF"
ip address 10.2.8.34 255.255.255.248
ip nat outside
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
interface GigabitEthernet0/2.1
encapsulation dot1Q 1 native
ip address 10.10.0.254 255.255.255.0
ip wccp web-cache redirect in
ip nat inside
interface GigabitEthernet0/2.2
encapsulation dot1Q 2
ip address 10.10.1.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/2.3
encapsulation dot1Q 3
ip address 10.10.2.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/2.4
encapsulation dot1Q 4
ip address 10.10.3.1 255.255.255.0
interface GigabitEthernet0/2.5
encapsulation dot1Q 5
ip address 10.10.4.1 255.255.255.0
interface GigabitEthernet0/2.6
encapsulation dot1Q 6
ip address 10.10.5.1 255.255.255.0
interface GigabitEthernet0/2.7
encapsulation dot1Q 7
ip address 10.10.6.1 255.255.255.0
interface GigabitEthernet0/2.8
encapsulation dot1Q 8
ip address 10.10.7.1 255.255.255.0
interface GigabitEthernet0/2.9
encapsulation dot1Q 9
ip address 10.10.8.1 255.255.255.0
interface GigabitEthernet0/2.10
encapsulation dot1Q 10
ip address 10.10.9.1 255.255.255.0
interface GigabitEthernet0/2.11
encapsulation dot1Q 11
ip address 10.10.10.1 255.255.255.0
interface GigabitEthernet0/2.12
encapsulation dot1Q 12
ip address 10.10.11.1 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map MAF interface GigabitEthernet0/1 overload
ip nat inside source route-map MICROCOM interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 10.2.8.33 track 10
ip route 0.0.0.0 0.0.0.0 10.0.7.1 track 11
access-list 10 permit 10.10.0.1
access-list 120 deny   ip host 10.10.0.1 any
access-list 120 permit ip 10.10.0.0 0.0.0.255 any
access-list 120 deny   ip any any
access-list 120 permit tcp 10.10.0.0 0.0.0.255 any eq www
route-map MICROCOM permit 10
match ip address 10 120
set default interface GigabitEthernet0/0
route-map MAF permit 10
set default interface GigabitEthernet0/1
control-plane
line con 0
password 7 ********************************************************
logging synchronous
login
line vty 0 4
access-class 23 in
privilege level 15
logging synchronous
login
transport input telnet ssh
scheduler allocate 20000 1000
end
Jon Marshall
Pierre
Can you try modifying your route map config. Remove the set default interface lines and add match interface lines ie.
match interface gi0/0
match interface gi0/1
Jon
I agree with Jon. The set interface syntax works when you are doing Policy Based Routing. For address translation the route map needs to match the interface and not set the interface.
Rick
Rick
Thanks John, It works I'm very happy.
