Dual WAN Load-balancing with Static NAT
KUNAL HANS
My scenario is similar to what has been discussed here: https://supportforums.cisco.com/thread/2067691
  • Two WAN interfaces of Cisco 2921 router connected to 2 ISP leased lines
  • Static NAT entries on router mapped to web/mail/ftp servers
  • Need to load-balance outbound traffic
  • ASA behind router with no services running as of now, default route towards router.
  • Catalyst 3560 L3 switch behind ASA with servers directly connected
This was my earlier config. Problem was with both WAN links active, inbound connections to mapped servers used to be intermittent at best. If I shut the AIRTEL link everything used to work as expected.
interface GigabitEthernet0/0
description "AIRTEL WAN LINK"
ip address 185.74.201.66 255.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description "TATA WAN LINK"
ip address 62.17.239.179 255.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex full
speed 100
interface GigabitEthernet0/2
description "LAN INTERFACE"
ip address 192.168.100.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
no ip virtual-reassembly in
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map AIRTEL interface GigabitEthernet0/0 overload
ip nat inside source route-map TATA interface GigabitEthernet0/1 overload
ip nat inside source static 192.168.100.2 62.17.239.178
ip nat inside source static 192.168.0.44 62.17.239.180
ip nat inside source static 192.168.0.176 62.17.239.184
ip nat inside source static 192.168.0.5 62.17.239.185
ip route 0.0.0.0 0.0.0.0 185.74.201.65
ip route 0.0.0.0 0.0.0.0 66.17.239.177
ip route 10.11.1.0 255.255.255.0 62.17.239.177
ip route 192.168.0.0 255.255.255.0 192.168.100.2          -- ASA outside IP
access-list 110 deny   ip 192.168.0.0 0.0.0.255 10.11.1.0 0.0.0.255
access-list 110 permit ip 192.168.0.0 0.0.0.255 any
access-list 110 permit ip 192.168.100.0 0.0.0.255 any
access-list 110 permit ip 192.168.1.0 0.0.0.255 any
no cdp run
route-map TATA permit 10
match ip address 110
match interface GigabitEthernet0/1
route-map AIRTEL permit 10
match interface GigabitEthernet0/0
This is the new config, after referencing the above thread and making necessary changes. Now, the inbound connectivity is completely down and I'm unable to ping the Global inside addresses of the servers. What am i missing?
interface Loopback100
description Used for static NAT services
ip address 192.168.101.1 255.255.255.252
ip nat outside
ip policy route-map STATIC-NAT-LOOP
interface Embedded-Service-Engine0/0
no ip address
shutdown
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex auto
speed auto
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex full
speed 100
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip policy route-map STATIC-NAT-LAN
duplex auto
speed auto
ip http server
ip nat inside source static 192.168.100.2 62.17.239.178 extendable
ip nat inside source static 192.168.0.44 62.17.239.180 extendable
ip nat inside source static 192.168.0.176 62.17.239.184 extendable
ip nat inside source static 192.168.0.5 62.17.239.185 extendable
ip nat inside source static 192.168.0.44 185.74.201.70 extendable
ip route 0.0.0.0 0.0.0.0 62.17.239.177
ip access-list extended STATIC-NAT-AIRTEL
permit ip host 185.74.201.70 any
ip access-list extended STATIC-NAT-SERVICES
permit ip host 192.168.0.44 any
permit ip host 192.168.0.176 any
permit ip host 192.168.0.5 any
permit ip host 192.168.100.2 any
ip access-list extended STATIC-NAT-TATA
permit ip host 62.17.239.180 any
permit ip host 62.17.239.184 any
permit ip host 62.17.239.185 any
permit ip host 62.17.239.178 any
no cdp run
route-map STATIC-NAT-LAN permit 10
match ip address STATIC-NAT-SERVICES
set ip next-hop 192.168.101.2
route-map STATIC-NAT-LOOP permit 10
match ip address STATIC-NAT-TATA
set ip next-hop 62.17.239.177
route-map STATIC-NAT-LOOP permit 20
match ip address STATIC-NAT-AIRTEL
set ip next-hop 185.74.201.65
KUNAL HANS
Would appreciate it if someone can take a look...badly stuck...thx!
MUKUL JOSHI
Hi Kunal,
Remove this PBR and confirm back.
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip policy route-map STATIC-NAT-LAN  <<<<<
duplex auto
speed auto
MJ
Yep, i did that already since I lost all inbound connectivity. I meant for someone to point out any mistakes in my config which was causing this to happen. It seems like a tried and tested config template since it worked for the OP in the thread I referenced.
Currently I just have a simple route-map applied on the LAN interface to force all traffic originating from the servers to go out from Gig0/1 and removed the static nat mapping of the other ISP as a temporary workaround. But ultimately I want each server to be mapped with public ip's of both ISP's.
