Dual WAN PPPoE
paulierco
Hi all,
I have a Cisco 892 with 2 ISP connection, both of them with PPPoE, both connection are from the same ISP and have the same speed. I want to use both connection at the same time.
The problem is when both Dialer 1 and Dialer 2 are up, only some webpages and some ip are working, some of them are down or no ping response.
Current configuration : 3227 bytes
! Last configuration change at 20:52:24 UTC Wed Jan 14 2015
version 15.2
service password-encryption
hostname R1
boot-start-marker
boot system flash:c890-universalk9-mz.152-1.T.bin
boot-end-marker
enable secret 5 $1$JV0k$qFkH1iLsyzfpKQQpmMMfz.
enable password 7 121A0C041104
no aaa new-model
service-module wlan-ap 0 bootimage autonomous
no ip dhcp use vrf connected
ip dhcp pool lan
 network 192.168.4.0 255.255.255.0
 default-router 192.168.4.1
 dns-server 8.8.8.8
no ip domain lookup
ip cef
no ipv6 cef
license udi pid CISCO892W-AGN-E-K9 sn FCZ1422C135
username paulierco privilege 15 secret 5 $1$oRrI$Nr18GHkQ6n74Bc/CdPNPF1
interface Loopback0
 no ip address
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
 isdn termination multidrop
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface FastEthernet4
 no ip address
interface FastEthernet5
 no ip address
interface FastEthernet6
 no ip address
interface FastEthernet7
 no ip address
interface FastEthernet8
 no ip address
 duplex auto
 speed auto
 pppoe enable group global
 pppoe-client dial-pool-number 2
interface GigabitEthernet0
 description RDS1
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip tcp adjust-mss 1452
 duplex auto
 speed auto
 pppoe-client dial-pool-number 1
 no cdp enable
interface wlan-ap0
 description Service module interface to manage the embedded AP
 ip address 192.168.1.10 255.255.255.0
 arp timeout 0
interface Wlan-GigabitEthernet0
 description Internal switch interface connecting to the embedded AP
 switchport mode trunk
 no ip address
interface Vlan1
 ip address 192.168.4.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
interface Dialer1
 mtu 1492
 ip address negotiated
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp pap sent-username AR212169617 password 7 0502031D22435D0817
 ppp ipcp dns request accept
 ppp ipcp route default
 ppp ipcp address accept
interface Dialer2
 mtu 1492
 ip nat outside
 encapsulation ppp
 dialer pool 2
 dialer-group 2
 ppp pap sent-username PPP19026277 password 7 062D2E0F6E762D
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 100 interface Dialer1 overload
access-list 100 permit ip 192.168.4.0 0.0.0.255 any
control-plane
mgcp profile default
banner motd ^Cmessage of the day^C
line con 0
 password 7 060506324F41
 logging synchronous
 login
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin udptn ssh
line aux 0
line vty 0 4
 password 7 070C285F4D06
 login
 transport input telnet ssh
scheduler max-task-time 5000
end
After i did some digging with ip nat translation i found that only Dialer 1  works and i have no traffic from Dialer 2.
R1#show ip interface brief
Interface                  IP-Address      OK? Method Status                Protocol
BRI0                       unassigned      YES NVRAM  administratively down down
BRI0:1                     unassigned      YES unset  administratively down down
BRI0:2                     unassigned      YES unset  administratively down down
Dialer1                    86.125.201.40   YES IPCP   up                    up
Dialer2                    86.125.209.138  YES IPCP   up                    up
FastEthernet0              unassigned      YES unset  down                  down
FastEthernet1              unassigned      YES unset  down                  down
FastEthernet2              unassigned      YES unset  down                  down
FastEthernet3              unassigned      YES unset  up                    up
FastEthernet4              unassigned      YES unset  up                    up
FastEthernet5              unassigned      YES unset  down                  down
FastEthernet6              unassigned      YES unset  down                  down
FastEthernet7              unassigned      YES unset  down                  down
FastEthernet8              unassigned      YES NVRAM  up                    up
GigabitEthernet0           unassigned      YES NVRAM  up                    up
Loopback0                  unassigned      YES unset  up                    up
NVI0                       192.168.1.10    YES unset  up                    up
Virtual-Access1            unassigned      YES unset  up                    up
Virtual-Access2            unassigned      YES unset  up                    up
Virtual-Access3            unassigned      YES unset  up                    up
Vlan1                      192.168.4.1     YES NVRAM  up                    up
Wlan-GigabitEthernet0      unassigned      YES unset  up                    up
wlan-ap0                   192.168.1.10    YES NVRAM  up                    up
Pro Inside global         Inside local          Outside local         Outside global
udp 86.125.201.40:20481   192.168.4.116:20481   145.255.179.216:20820 145.255.179.216:20820
udp 86.125.201.40:20481   192.168.4.116:20481   151.225.129.78:53754  151.225.129.78:53754
udp 86.125.201.40:20481   192.168.4.116:20481   154.20.117.60:6881    154.20.117.60:6881
Thanks and any advice are welcome,
Paul
3 Accepted Solutions
Your NAT is configured in a way that regardless of the outgoing interface, always Di1-IP is used. That can be corrected with the following NAT:
ip nat inside source route-map NAT-1 interface Dialer1 overload
ip nat inside source route-map NAT-2 interface Dialer2 overload
route-map NAT-1 permit 10
 match ip address 100
 match interface Dialer1
route-map NAT-2 permit 10
 match interface Dialer2
And most important: Change the passwords on your Router NOW!!!
what is the actual NAT-config? Your old dynamic nat "ip nat inside source ..." has to be replaced by the new config.
5 Replies 5
HI,
Router is a temporary setup, is not on use.
I try your configuration but it doesn't work, same problem.
You're a great man! It works!
