Dualhoming Design
Rinam Shah
In the below Topology, I want to make secondary link running the BGP and primary link as the default route. Due to prefix length matching takes place before AD, the primary link is the BGP.
Please help me with below topology and network config.
R3:
track 11 ip sla 1 reachability
interface Loopback0
ip address 3.3.3.3 255.255.255.255
ip ospf network point-to-point
interface Ethernet0/0
no ip address
shutdown
duplex auto
interface GigabitEthernet0/0
ip address 10.0.13.2 255.255.255.252
ip ospf cost 100
ip ospf 100 area 0
duplex full
speed 1000
media-type gbic
negotiation auto
interface GigabitEthernet1/0
ip address 10.0.23.2 255.255.255.252
ip ospf cost 120
ip ospf 100 area 0
negotiation auto
router ospf 100
log-adjacency-changes
network 3.3.3.3 0.0.0.0 area 0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 track 11
ip sla 1
icmp-echo 10.0.13.1 source-ip 10.0.13.2
ip sla schedule 1 life forever start-time now
end
R1:
ip address 10.0.13.1 255.255.255.252
duplex full
speed 1000
media-type gbic
negotiation auto
ip address 14.0.0.1 255.255.255.252
negotiation auto
router ospf 100
ip route 0.0.0.0 0.0.0.0 GigabitEthernet1/0
no ip http server
no ip http secure-server
end
R2:
ip address 24.0.0.1 255.255.255.252
duplex full
speed 1000
media-type gbic
negotiation auto
ip address 10.0.23.1 255.255.255.252
ip ospf 100 area 0
negotiation auto
router ospf 100
redistribute bgp 100 subnets
router bgp 100
no synchronization
bgp log-neighbor-changes
network 24.0.0.0 mask 255.255.255.252
redistribute connected
redistribute ospf 100
neighbor 24.0.0.2 remote-as 4755
no auto-summary
end
R4:
ip address 24.0.0.2 255.255.255.252
duplex full
speed 1000
media-type gbic
negotiation auto
ip address 14.0.0.2 255.255.255.252
negotiation auto
interface GigabitEthernet2/0
ip address 172.31.45.2 255.255.255.252
negotiation auto
router bgp 4755
no synchronization
network 14.0.0.0 mask 255.255.255.252
neighbor 24.0.0.1 remote-as 100
neighbor 172.31.45.1 remote-as 4755
neighbor 172.31.45.1 next-hop-self
no auto-summary
end
R5:
ip address 56.0.0.1 255.255.255.252
negotiation auto
ip address 172.31.45.1 255.255.255.252
negotiation auto
router bgp 4755
no synchronization
network 56.0.0.0 mask 255.255.255.252
neighbor 56.0.0.2 remote-as 200
neighbor 172.31.45.2 remote-as 4755
neighbor 172.31.45.2 next-hop-self
no auto-summary
end
R6:
ip address 192.168.67.2 255.255.255.252
ip ospf 100 area 0
duplex full
speed 1000
media-type gbic
negotiation auto
ip address 56.0.0.2 255.255.255.252
negotiation auto
router ospf 100
redistribute bgp 200 subnets
router bgp 200
no synchronization
neighbor 56.0.0.1 remote-as 4755
no auto-summary
end
R7:
interface Loopback0
ip address 7.7.7.7 255.255.255.255
ip address 192.168.67.1 255.255.255.252
ip ospf 100 area 0
duplex full
speed 1000
media-type gbic
negotiation auto
no ip address
shutdown
negotiation auto
router ospf 100
network 7.7.7.7 0.0.0.0 area 0
end
7 Replies 7
Giuseppe Larosa
Hello @Rinam Shah ,
first of all , the configuration that you have posted are not complete for example I don't see a section for address-family ipv4 vrf <vrf-name> on PE R4 where I should see redistribute of static routes and the eBGP session with CE R2.
Most specific prefixes are used first so the eBGP session between CE R2 and PE R4 is your primary exit point from the multihomed VRF site.
What about using eBGP also on R1-R4 and then using local preference to make R1-R4 the preferred exit point ?
You could combine this with a lower MED sent by R1 in comparison to R2 and you would get R1-R4 link used for both directions for user traffic.
You can set the local preference at neighbor level using a command like
neighbor 14.0.0.4 local-preference 300 on R1
Hope to help
Giuseppe
Hi @Giuseppe Larosa,
I am not using MPLS or any VPN.
I am using BGP between PE-PE and PE-CE. In LAN, I am using OSPF and have redistributed from OSPF to BGP to advertise my LAN routes and redistributed from BGP to OSPF at CE itself. This is working fine but the problem is when I use the default route from R1 to R4 and I want to make this link as primary.
Please suggest what can I do here to make this link R1-R4 as primary for outbound traffic.
Rinam Shah
Hello @Rinam Shah ,
PE and CE usually refers to MPLS L3 VPN for this reason I thought about it.
Use an eBGP session between R1 and R4
on R1 make the peer local preference increased from standard value 100 using neighbor 14.0.0.4 local-preference 200 under router bgp in R1.
Have an iBGP session between R1 and R2
Redistribute eBGP into OSPF in R1 . Have R2 to just generate a default route in OSPF (do not distribute eBGP to OSPF in R2)
The same suggestions I have provided in my previous post are stil valid as the changes are on the "CE" side I have added some more actions
Hope to help
Giuseppe
I want to use only default route between R1 and R4 and make this link as primary so that in case of link down, it can instantly failover to BGP secondary link.
I do not want to run dynamic protocol at between R1 and R4. Also, I want to make it as primary link.
Hello @Rinam Shah ,
on R2 you need to remove the redistrbution of eBGP into OSPF.
Both R1 and R2 will generate a default-route in OSPF but R1 will use a lower seed metric
R1:
ip prefix-list DEFAULT permit 0.0.0.0/0
access-list 11 remark check next-hop
access-list 11 permit host 14.0.0.4
route-map DEF-CHECK_NHOP permit 10
match address prefix DEFAULT
match next-hop 11
set metric type 1
set metric 50
router ospf 100
network 0.0.0.0 255.255.255.255 area 0
default-information originate route-map DEF-CHECK_NHOP
on R2:
set metric type 1
set metric 5000
router ospf 100
no redistribute bgp 100 subnets
default-information originate DEF-CHECK_NHOP
Please note that R1 needs to speak OSPF with R3 otherwise there is no real solution. Also R4 needs to send a default route in eBGP to R2.
For the lower seed metric R1 will become the preferred exit point from the multihomed site if the link between R1 and R4 fails the static route is removed and the secondary default route generated by R2 with an higher seed metric will kick off.
Hope to help
Giuseppe
I made the changes as you mentioned and I am able to ping R7 from R3 with primary link as R1-R4. But when I shut the R2's WAN interface Gi0/0, I am not able to reach R7.
Please find the below topology and config along with the output when the R2 interface is shut.
Output:
Gateway of last resort is 10.0.13.2 to network 0.0.0.0
3.0.0.0/32 is subnetted, 1 subnets
O 3.3.3.3 [110/121] via 10.0.13.2, 01:09:53, GigabitEthernet0/0
7.0.0.0/32 is subnetted, 1 subnets
S 7.7.7.7 is directly connected, GigabitEthernet1/0
10.0.0.0/30 is subnetted, 2 subnets
C 10.0.13.0 is directly connected, GigabitEthernet0/0
O 10.0.23.0 [110/240] via 10.0.13.2, 01:09:53, GigabitEthernet0/0
14.0.0.0/30 is subnetted, 1 subnets
C 14.0.0.0 is directly connected, GigabitEthernet1/0
O*E1 0.0.0.0/0 [110/5240] via 10.0.13.2, 00:21:24, GigabitEthernet0/0
Router(config)#do ping 7.7.7.7 so g1/0
Sending 5, 100-byte ICMP Echos to 7.7.7.7, timeout is 2 seconds:
Packet sent with a source address of 14.0.0.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 72/84/100 ms
Router(config)#do ping 7.7.7.7 so g0/0
Packet sent with a source address of 10.0.13.1
Success rate is 0 percent (0/5)
Config:
R3:
interface Loopback0
no ip address
shutdown
duplex auto
ip ospf cost 100
ip ospf 100 area 0
duplex full
speed 1000
media-type gbic
negotiation auto
ip ospf cost 120
ip ospf 100 area 0
negotiation auto
router ospf 100
end
R1:
ip ospf cost 120
ip ospf 100 area 0
duplex full
speed 1000
media-type gbic
negotiation auto
negotiation auto
router ospf 100
ip route 7.7.7.7 255.255.255.255 GigabitEthernet1/0
ip prefix-list DEFAULT seq 5 permit 0.0.0.0/0
match ip address prefix-list DEFAULT
set metric 50
set metric-type type-1
end
R2:
shutdown
duplex full
speed 1000
media-type gbic
negotiation auto
ip ospf 100 area 0
negotiation auto
router ospf 100
router bgp 100
no synchronization
no auto-summary
set metric 5000
end
R4:
duplex full
speed 1000
media-type gbic
negotiation auto
negotiation auto
negotiation auto
router bgp 4755
no synchronization
no auto-summary
end
R5:
negotiation auto
negotiation auto
router bgp 4755
no synchronization
no auto-summary
end
R6:
ip ospf 100 area 0
duplex full
speed 1000
media-type gbic
negotiation auto
negotiation auto
router ospf 100
router bgp 200
no synchronization
no auto-summary
end
R7:
interface Loopback0
ip ospf 100 area 0
duplex full
speed 1000
media-type gbic
negotiation auto
no ip address
shutdown
negotiation auto
router ospf 100
end
Hello @Rinam Shah ,
we need to provide a return path from R7 to R3 for this case.
First of all,
on R4 you need static routes describing all the possible subnets connected to R3 with next-hop R1 on R1-R4 link
on R4:
ip route 10.0.13.0 255.255.255.252 14.0.0.1
ip route 10.0.23.0 255.255.255.252 14.0.0.1
and to redistrbute them in BGP
ip prefix-list SITE1 permit 10.0.13.0/30
ip prefix-list SITE1 permit 10.0.23.0/30
route-map SITE1 permit 10
match address prefix SITE1
router bgp 100
redistribute static route-map SITE1
at the same time R4  needs to avoid  to advertise these subnets to R2 when eBGP session between them is alive.
route-map To-R2 deny 10
route-map To-R2 permit 20
router bgp 100
neighbor 24.0.0.1 route-map To-R2 out
This should be enough to provide end to end connectivty when R2-R4 link is down
As you can see these are the drawbacks of using static routes you need to think of all possible cases including faults and you need to configure static routes on both sides of R1-R4 link.
Hope to help
Giuseppe
