Duplex mismatch between Router and Core Switch, %CDP-4-DUPLEX_MISMATCH
din_nevermind
I have a problem here. There is 10M links for the site. It's having duplex mismatch between Router1 and CoreSW2. The connection are as below;
Router1 (G0/1) <=====Duplex mismatch"=====>(G0/11)CoreSW2<=====Fine=====>(G0/2.156)Router2
When we change the configuration on Int G0/11, CoreSW2 to Full-Duplex and Speed 100Mbps, the link went down. Then we configure it back as Half-Duplex and Speed 100Mbps.
Can anyone please advise on how to solve this issue? Is there any misconfiguration between the link or need to change some interface media?
Thanks in advance.
Router1:
Router1#sh int GigabitEthernet0/1
GigabitEthernet0/1 is up, line protocol is up
  Hardware is MV96340 Ethernet, address is 001e.f7e5.b741 (bia 001e.f7e5.b741)
  Description: *** 10M Tata to Chennai, in-che-colo-partrtr01 ID: New: 4008001438 / Old: 77-14110067 ***
  Internet address is 10.127.189.26/30
  MTU 2000 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is T
  output flow-control is XON, input flow-control is XON
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 1d14h
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 83000 bits/sec, 30 packets/sec
  5 minute output rate 33000 bits/sec, 30 packets/sec
     23984796 packets input, 2835615576 bytes, 0 no buffer
     Received 17326 broadcasts, 0 runts, 0 giants, 0 throttles
     30 input errors, 0 CRC, 30 frame, 0 overrun, 0 ignored
     0 watchdog, 0 multicast, 0 pause input
     19209986 packets output, 1977760822 bytes, 0 underruns
     0 lost carrier, 0 no carrier, 0 pause output
Router1#
Jul 31 23:18:21.420 UTC: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet0/1 (not half duplex), with CoreSW2 GigabitEthernet0/11 (half duplex).
Jul 31 23:19:21.425 UTC: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet0/1 (not half duplex), with CoreSW2 GigabitEthernet0/11 (half duplex).
Jul 31 23:20:21.429 UTC: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet0/1 (not half duplex), with CoreSW2 GigabitEthernet0/11 (half duplex).
CoreSW2
CoreSW2>sh int Gi0/11
GigabitEthernet0/11 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 001e.4913.608b (bia 001e.4913.608b)
  Description: *** Sasken ***
  MTU 9000 bytes, BW 100000 Kbit, DLY 100 usec,
  Half-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:28, output 00:00:00, output hang never
  5 minute input rate 34000 bits/sec, 33 packets/sec
  5 minute output rate 88000 bits/sec, 34 packets/sec
     6033864740 packets input, 1448080850993 bytes, 0 no buffer
     Received 6045789 broadcasts (0 multicasts)
     2 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 6045696 multicast, 91761294 pause input
     7957047026 packets output, 7248383697947 bytes, 0 underruns
     0 output errors, 212968 collisions, 17 interface resets
     0 babbles, 2686383 late collision, 0 deferred
Jul 31 23:15:02.650 UTC: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet0/11 (not full duplex), with iRouter1 GigabitEthernet0/1 (full duplex).
Jul 31 23:16:02.646 UTC: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet0/11 (not full duplex), with iRouter1 GigabitEthernet0/1 (full duplex).
Jul 31 23:17:02.650 UTC: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet0/11 (not full duplex), with Router1 GigabitEthernet0/1 (full duplex).
Jul 31 23:18:02.646 UTC: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet0/11 (not full duplex), with Router1 GigabitEthernet0/1 (full duplex).
Jul 31 23:19:02.650 UTC: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet0/11 (not full duplex), with Router1 GigabitEthernet0/1 (full duplex).
Router2
Router2>sh int Gi0/2.156
GigabitEthernet0/2.156 is up, line protocol is up
  Hardware is BCM1250 Internal MAC, address is 0021.563a.581a (bia 0021.563a.581a)
  Description: 10M EoSDH Tata Teleservices to Sasken Bangalore, in-blr-sasken-extrartr01 ID:New 4008001438 / Old  77-14110067 ***
  Internet address is 10.127.189.25/30
  MTU 2000 bytes, BW 1000000 Kbit, DLY 10 usec,
  Encapsulation 802.1Q Virtual LAN, Vlan ID  156.
Router21>
GigabitEthernet0/2 is up, line protocol is up
  Description: cvcolo-coresw02 Gi0/5 ***
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Full-duplex, 1000Mb/s, media type is RJ45
  Input queue: 0/75/65/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: Class-based queueing
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/2/256 (active/max active/max total)
     Reserved Conversations 3/3 (allocated/max allocated)
     Available Bandwidth 250000 kilobits/sec
  5 minute input rate 84000 bits/sec, 91 packets/sec
  5 minute output rate 110000 bits/sec, 45 packets/sec
     10330613341 packets input, 1815547116247 bytes, 22 no buffer
     Received 261218305 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog, 178212613 multicast, 0 pause input
     6112381585 packets output, 5097320965256 bytes, 0 underruns
     4 output errors, 0 collisions, 3 interface resets
     4 lost carrier, 0 no carrier, 0 pause output
Nagaraja Thanthry
The duplex mismatch happens when the two ports do not negotiate the
speed/duplex/other parameters. Please configure both ends to negotiate the
speed/duplex settings. If your link is 100 Mbps, then you can configure
traffic shaping to limit the bandwidth.
http://www.cisco.com/en/US/customer/products/hw/switches/ps700/products_tech
note09186a00800a7af0.shtml#autoneg_valid
http://www.dell.com/content/topics/global.aspx/power/en/ps1q01_hernan?c=us&c
s=555&l=en&s=biz
Hope this helps.
NT
jean.moncada
You should do the following, (btw I recommend setting speed to 1000 not 100 since they are both Gig ports unless you trying to limit your bandwidth)
anyways by the output on your log the problem is with CoreSW2 gi0/11 its only set to half duplex.
I recommend making the following changes
on Router1 (G0/1)
speed 1000
duplex full
and on CoreSW2 (G0/11)
speed 1000
duplex full
that should fix your duplexing problem.
