Dyanamic NAT and VPN
Mero Cisco
Dear All,
I need a configuration for NAT and VPN on the same router. Is this possible or not, please go through the attached diagram.
Thanks in advance for your kind cooperation.
Mero
rafael_acc
good luck with your homework
ghostinthenet
Level 7
Level 7
It's definitely possible. What you need to do is set up a NAT configuration using an extended ACL, a route map and a NAT pool on router B. The ACL will dictate what traffic will be subject to NAT and the NAT pool will define the translated source. You'll likely need a static route for the translated source on router C, pointing back to router B.
As rafael_acc has pointed out, this looks more like a homework assignment than a real-life problem, so I'm only providing general direction rather than a working configuration. Hopefully that sets you on the right track.
Check out the Cisco Learning Network for a more education-oriented forum as well. It's definitely worthwhile.
Jody Lemoine, Network Architect
CCIE 41436, MTCRE, MTCINE, MTCIPv6E
tishco networks, Virtually Everywhere
(905) 378-1134, jody.lemoine@tishco.ca
