Dynamic bandwidth division on serial
professionale
I' m trying to set some bandwidth division rules to divide dinamically the bandwith
between 2 lan.
I mean if one of the lan doesn't use his assigned bandwith or part of it, the other Lan can use also the free part of bandwith.
I have to apply this in INPUT and OUTPUT. Wath Have i to use?
Can any help, plz?
18 Replies 18
leighharrison
Level 7
Level 7
Hi there,
You need to use QoS on the link. Depending on how much you want each lan to have, I would opt for something like "bandwidth percent 50" in the policy map, or even "priority percent 50" check out this link for more details:-
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fqos_c/fqcprt8/qcfmcli2.htm
LH
Please rate all posts
Thx very useful guide but I' m not understending one thing.
If I apply a policy on the serial I can set only the output direction (not the input one), but i want to limit either download and upload from internet.
How can I do that?
thx
Hi there,
Best thing to do is also apply the policy outbound on the ethernet interface too, so that it can only go at a certain speed through the router either way.
LH
thx here the conf I' ve created.....
conf t
access-list 110 remark "Lan1serialOUT"
access-list 110 permit ip 192.168.180.0 0.0.0.255 any
access-list 110 permit ip 192.168.99.128 0.0.0.127 any
access-list 120 remark "Lan2serialOUT"
access-list 120 permit ip 192.168.99.0 0.0.0.127 any
class-map match-all Lan1
match access-group 110
class-map match-all Lan2
match access-group 120
policy-map OUT
class Lan1
police 1100000 206000 250000 conform-action transmit exceed-action drop
exit
class Lan2
police 700000 100000 150000 conform-action transmit exceed-action drop
exit
class class-default
fair-queue 20
exit
int serial 1/0
service-policy output OUT
Now im not understanding wath I have to apply on ethernet and fastethernet
int eth 0/0
int fa 2/0
Have I to set these access lists for the 2 interfaces?
access-list 130 remark "ethernetOUT"
access-list 130 permit ip any 192.168.180.0 0.0.0.255
access-list 130 permit ip any 192.168.99.128 0.0.0.127
access-list 140 remark "fastethernetOUT"
access-list 140 permit ip any 192.168.99.0 0.0.0.127
Have I to consider the inbound traffic from internet or wath?
thx in advance!
Hi there,
You need to think about the flow of traffic for the access lists. If you got:-
1.x.x.x ---- router ---- 2.x.x.x
For one way you need to specify traffic going TO 2.x.x.x and the other way you need to specify traffic coming FROM 2.x.x.x
LH
Have I to apply both "incoming" ACL and "outgoing" ACL as service-policy output?
Create 2 policy maps. One for incoming traffic and one for out going traffic. Then apply the relevant on to the interface. You'll need 2 access lists per range, TO and FROM, so that'll mean 2 class maps per range too.
LH
I'm not understanding how to apply these policies, couse router doesnt accept any policy in input on the serial.
plz, follow this example....
class-map match-all Lan1OUT
class-map match-all Lan2OUT
class-map match-all Lan1IN
match access-group 130
class-map match-all Lan2IN
match access-group 140
policy-map serialOUT
class Lan1OUT
bandwidth percent 40
exit
class Lan2OUT
bandwidth percent 35
exit
policy-map serialIN
class Lan1IN
exit
class Lan2IN
exit
int s 1/0
service-policy output serialOUT
(this works)
service-policy input serialIN
(doesnt appare in running-config)
where have I to apply serialIN rules?
Hello again,
The serialIN policy should work on the inbound traffic if you are policing. If it's not working, then you can apply it on the interface that the traffic uses to go out of, usualyy an ethernet connection.
LH
ok thx i'll try .....
Only one other thing...I think this can work well 4 TCP traffic, but I' m not so sure 4 UDP one...
Hi there,
What bits of UDP traffic are you trying to match?
LH
Well, i want to limit udp traffic too..
serial output policy---R---ethernet output policy
if i'll apply these policies TCP will be limited in input on the serial by the windowing but UDP got none, so i was thinking, wath will happen 4 UDP traffic?
Hi there,
You simply have to specify the traffic with either an access list in the class map or use nbar. The same as you would for TCP.
LH
