dynamic NAT inside -> outside and static NAT outside -> inside on the same device
bartemye
I have a single router that I'd like to perform source and destination NAT at the same time.
Possible?
I.e.
interface FastEthernet0
ip nat outside
ip add 10.1.1.1.255.255.255.0
interface FastEthernet1
ip nat inside
ip add 192.168.1.1 255.255.255.0
ip nat inside source route-map dynamic_nat_map interface FastEthernet0 overload
ip nat outside source static 10.100.1.24 192.168.2.24
ip route 172.16.0.0 255.240.0.0 192.168.1.2
ip access-list extended dynamic_nat_acl
permit ip 172.16.0.0 255.240.0.0 192.168.2.0 0.0.0.255
route-map dynamic_nat_map permit 10
match ip address dynamic_nat_acl
I'd like users on 172.16.0.0/12 connect to 10.100.1.24, but they must appear as 192.168.1.1 and 10.100.1.24 needs to appear to them as 192.168.2.24
andrew.prince
Level 10
Level 10
Boris,
Where is the 172.16/12 ?
Where is the 10.100.1.x ?
