Dynamic routing for backup Tunnel
benolyndav
Level 4
Level 4
HI
See diagram, so we want to set up another ipsec vpn on the network on the left which is our other DC, how could we set this up so if the 172.25.192.0/19 network wasnt available on the network on the right (DC1) then the routingwould dynamically point to DC2 on the left.
8 Replies 8
I dont get you Q
can you more elaborate
so from the diagram you see that we have a IPSEc VPN to AWS where the /19 resides,
network on right DC1
we have a static route pointg to firewall for /19 on the 9500 stack, this is then redistributed into BGP and advertised to the ISP router.
Network on left side DC2
we would like to set up a secondary IPSEC VPN to AWS and if we loose the primary IPSEC VPN we want the routing to then point to DC2 for the /19,
i was thinking maybe ospf on the Firewall and advertise just the /19 and then if we loose the the firewall etc then dynamically route to DC2. I also realise I will neeed isp assistance .?
rais
Level 7
Level 7
Do you intend to use AWS backbone to get to /19 [right] network or does the /19 has another instance in the left AWS region? You need a dynamic routing protocol.
The /19 resides in AWS,
You mention ipsec and I dont know from which point from edge router or from ASA?
ASA public internet  the ISP routers are our private MPLS provided by Virgin
just mention in your topology from where to where the VPN connection
if you can please
From ASA to Cloud (AWS)
