E1 link with NM-2CE1T1-PRI module
obah
Hi Guys,
             I'm not very familiar with this card, I have this problem , when i type sh ip int brief ;
rtr2#sh ip int brief
Interface                  IP-Address      OK?       Method   Status                Protocol
GigabitEthernet0/0         172.21.40.5     YES NVRAM  up                    up
GigabitEthernet0/1         172.21.40.5     YES NVRAM  standby mode    down
Serial1/0:0                10.20.197.1          YES manual    reset                 down
Serial1/1:0                unassigned      YES manual administratively down down
Serial2/0:0                unassigned      YES manual administratively down down
Serial2/1:0                unassigned      YES unset  reset                 down
Serial3/0:0                unassigned      YES unset  reset                 down
Serial3/1:0                unassigned      YES unset  reset                 down
Serial4/0                  unassigned      YES manual down                  down
Serial4/1                  unassigned      YES manual down                  down
Serial4/2                  unassigned      YES unset  administratively down down
Serial4/3                  unassigned      YES unset  administratively down down
NVI0                       unassigned      YES unset  up                    up
Multilink120               172.21.80.1     YES manual down                  down
may i know what does this reset mean instead of down status?
Thanks!
what model of router is this?
did you tried an OIR ?
I have seen this happening when OIR is not supported, so a reload of the box is needed.
or when having a faulty card.
please send more details of the issue, like show version, and steps applied to this card so far.
regards
Yesua.
Hi  Yesua,
                   The router is 3825 running ios ver Version 12.4(1c), config i believe is correct..
card type e1 1
card type e1 2
card type e1 3
controller E1 1/0
line-termination 75-ohm
channel-group 0 unframed
controller E1 1/1
controller E1 2/0
controller E1 2/1
controller E1 3/0
controller E1 3/1
interface Serial1/0:0
description E1 to Balun 28-A-1 (MCB)
bandwidth 2048
ip address 10.20.X.X 255.255.255.252
ip access-group 199 in
ip nat outside
no cdp enable
interface Serial1/1:0
no ip address
shutdown
interface Serial2/0:0
no ip address
shutdown
I not remove or insert the module..
The RA led is amber, could it be the remote side down?
Take "show controllers E1".
Most likely, bad cable or circuit failure.
