E1 PRI
resfat2001
Is this configuration correct for a data transfer from an E1 PRI
controller E1 1/0
framing NO-CRC4
pri-group timeslots 1-31
interface Serial1/0:15
ip address 192.168.150.34 255.255.255.224
no cdp enable
encapsulation ppp
dialer idle-timeout 119
dialer string xxxxxx
dialer-group 1
isdn switch-type primary-net5
isdn point-to-point-setup
ppp authentication chap pap callin
ppp chap hostname yyyyyyyy
ppp chap password zzzzzz
dialer-list 1 protocol ip permit
Wilson Samuel
Level 7
Level 7
Hey,
One question, if you want the entire 30 Channels to be dialed in simultaneously to the same destination why not use it as a E-1 rather than E-1 PRI.
I mean what is the need of PRI, if you can manage the same show with Channelized E-1 or E-1.
Otherwise in this config, I guess it should be fine.
