E1 solution for voice and data
emadehsan
Dear all,
I have three remote offices. they connected together with E1.
I have also three pbx in each location.
I want to use VWIC cards to integrate voice and data for this solutions.
is there any sample and web link to guide me?
paolo bevilacqua
Hi, which type of interface do the PBX have to connect to the router ?
hello
its G703 (e1) interface.
Hi, the best thing is you get a dual-port vwic card, and configure for voip. The smaller router you can use is a 1861, or a 2801.
This way the pbxs will have a full mesh link between themselves, and you can use all the bandwith saved for data.
hope this helps, please rate post if it does!
