E1 /T1 Config
CSCO10758684
Hai all,
One of my customer is facing the issue in IPLC (Ind to US ) ..india end its E1 ..were Us end is T1 ...Customer dont want to club 2 T1 to give E1 Output at US end ..
Is this setup possible ..if so what shud be the config at both router ..
Thanks in advance
Lijesh.N.C
paolo bevilacqua
most likely you will have full T1 in the US, and 24 timeslots E1 in India.
controller e1 x/y
channel-group 0 timeslots 1-24
Hai,
Thanks for the reply.
This is what the config what i did, Even though link is not up
India:
Controller E1 XXX
channel group 0 time slot 1 - 24
framing NO-CRC4
Line code HDB3
Clock source line
USA
Controller T1 XXX
Channel group 0 time slot 1-24
(can you get me what should be the rest of configuration in USA end)
Lijesh.N.C
Hai All,
Can any one help me regarding this ..
Config (framing NO-CRC4
Line code HDB3
Clock source line ) ...is modem config
Lijesh.N.C
