easy vpn crypto-6-ikmp_mode_failure :processing of aggressive mode failed with peer
bonan.xu
I got a problem to setup easy vpn. When I setup done for the easy vpn. It will work fine for a couple of days. Then the vpn will not work. and when I try use vpn client to connect router the router will get a message CRYPTO-6-IKMP_MODE_FAILURE : Processing of aggressive mode failed with peer at 192.168.0.76
And I also tried to reload it and work for 1-2 days then still not working and show that message for me.
version 12.4
hostname Router
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default local
aaa authentication login USER local
aaa session-id common
resource policy
clock timezone utc -7
clock summer-time CDT recurring
no network-clock-participate wic 2
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.0.1 192.168.0.110
ip dhcp pool group
   network 192.168.0.0 255.255.255.0
   default-router 192.168.0.1
   dns-server 192.168.0.7 75.75.75.75 75.75.76.76
   lease 0 4
username test password 0 test
controller T1 0/2/0
 framing esf
 linecode b8zs
crypto isakmp policy 1
 encr  aes
 hash md5
 authentication pre-share
 group 2
crypto isakmp key Cisco address 0.0.0.0 0.0.0.0
crypto isakmp client configuration address-pool local EZVPN_POOL
crypto isakmp client configuration group group
 key group
 dns 192.168.0.7 75.75.75.75
 wins 192.168.0.7
 pool EZVPN_POOL
 acl 100
 netmask 255.255.255.0
crypto isakmp profile EZVPN_PROFILE
   match identity group group
   client authentication list USER
   isakmp authorization list GROUP
   client configuration address respond
 virtual-template 1
crypto ipsec transform-set EZVPN_SET esp-aes esp-sha-hmac
crypto ipsec profile EZVPN_PROFILE
 set transform-set EZVPN_SET
 set isakmp-profile EZVPN_PROFILE
interface FastEthernet0/0
 ip address 192.168.0.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly
 duplex auto
 speed auto
interface FastEthernet0/1
 ip address 50.79.xx.xxx 255.255.255.248
 ip nat outside
 duplex auto
 speed auto
interface Virtual-Template1 type tunnel
 ip unnumbered FastEthernet0/1
 tunnel mode ipsec ipv4
 tunnel path-mtu-discovery
 tunnel protection ipsec profile EZVPN_PROFILE
ip local pool EZVPN_POOL 192.168.0.100 192.168.0.110
ip route 0.0.0.0 0.0.0.0 50.79.xx.xxx
ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/1 overload
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 100 permit ip 192.168.0.0 0.0.0.255 any
disable-eadi
control-plane
line con 0
line aux 0
line vty 0 4
end
Martin Moran
Level 3
Level 3
Hi @bonan.xu@caogro...,
The first think is that you have to make sure that all the ISAKMP parameters match at both ends of the VPN. Maybe there is something that the peers are negotiating or creating by themselves.
I let you this link here that can be useful:
http://www.cisco.com/c/en/us/support/docs/security-vpn/ipsec-negotiation-ike-protocols/46402-16b.html
HTH.
Rgrds,
Martin, IT Specialist
