Easy VPN on cisco router
jeevan.koganti
I am trying to create easy VPN on cisco 881 router. I have configured successfully and able to login also, but unfortunately not able to ping nor communicate to any computers on VPN LAN network.
Can anyone tell me where i am going wrong. Below is the config done.
interface loopback0 172.16.0.1
aaa new-model
aaa authentication login auth local
aaa authorization network auth local
ip local pool xyz 172.16.0.2 172.16.0.10
access-list 101 permit ip 172.16.0.0 0.0.0.255 any
crypto isakmp policy 10
encr 3des
authentication-preshare
group 2
crypto iaskmp client configuration group xyz
acl 101
key compaq
pool xyz
domain cisco.com optional
crypto isakmp profile isakmp-p(this is a word)
match identity group xyz
virtual-template 1
isakmp authorization auth
client authentication auth
client configuration address respond
crypto ipsec transform-set TS esp-3des esp-sha-hmac
mode transport
crypto ipsec profile S-S
set transform-set TS
set isakmp-profile ISAKMP-P
interface virtual-template 1 type tunnel
ip unnumbered fa0/0
tunnel protection ipsec profile S-S
tunnel mode ipsec ipv4
tunnel source fa0/0
Thanks in advance,
Emmanuel Valdez
Level 3
Level 3
Hi Jeevan,
Try with this configuration:
aaa new-model
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group xyz
key compaq
pool xyz
acl 101
   client authentication list auth
   isakmp authorization list auth
   virtual-template 1
interface Virtual-Template1 type tunnel
ip unnumbered FA0/0
access-list 101 permit ip X.X.X.X Y.Y.Y.Y any
Where X.X.X.X is your LAN computers segment.
      Y.Y.Y.Y is the wild card for the LAN computers segment.
Your actual ACL is wrong because the source address is your LAN computer and not the VPN Client IP address.
If it is useful please rate.
Best regards.
Hardik Vaidh
encr 3des
hash md5
group 2
crypto isakmp key XXX address 10.10.10.10
// set your key insted of XXX and it must match with your remote site. after that write address of your peer
crypto isakmp invalid-spi-recovery
crypto ipsec transform-set XXX esp-3des esp-md5-hmac
crypto map YYY  local-address <<>>
crypto map YYY 10 ipsec-isakmp
set peer 10.10.10.10
set transform-set ZZZ
match address 101
interface <<>>
crypto map YYYY
access-list 101 permit ip 192.168.1.0 0.0.0.255 11.11.11.11 (Remote user) 255.255.255.255
access-list 101 permit ip 192.168.1.0 0.0.0.255 22.22.22.22(Remote user) 255.255.255.255
After that configure NAT with req. access-list
For troubleshooting
sh cry ipsec sa peer 10.10.10.10
sh cry session
hope your IPSec site to site VPN tunnel is working fine
