NATing of one Private IP address with two ISP Internet IPs
Dipesh Patel
Level 2
Level 2
Dear Experts,
We are at present using VSNL internet iP addresses and recently purchased APNIC Internet IPs which is made live via Airtel internet Link.
Now we want to migrate all VSNL IPs with APNIC IP addresses and finally terminate Airtel Internet link and VSNL IPs.
The proposed solution is shown in the diagram.
Now for the migration purpose, we need to make both Interent IPs (VSNL and APNIC IPs ) live. So need to configure NAT of Single Private iP address to be NAT with two different IP address as shown in diagram.
1. Can you suggest how it will be?
2. or How can I use both internet IP pool live at a time?
Thanks in advance.
Dipesh
paul.strazza
Are all of the sessions originating from the internet?
Abzal
Level 7
Level 7
If the switch is Layer3 and you could run EIGRP routing on two CEs and switch. Then inject static default route from both CEs to EIGRP by redistributing. And L3 switch could do load-balancing. On CEs configure NAT overload.
Abzal
Best regards,
Abzal
Dear Abzal,
I do not want to use both the link and IPS permently.
My main purpose is NATING of one private IP address with two Public IP address each from two different ISP.
Pls help
Hardik Vaidh
try overload NAT. you have any firewall ??
