eBGP from a vrf to a neighbor ipv4 in global
gautamanish
i am trying to establish a ebgp from a vrf loopback towards a peer ip which is in global routing table and is being imported in vrf using following command
import from default-vrf route-policy <route-policy-name>
ping is happening but bgp is not coming up .
is it possible to establish bgp using source as interface in a vrf towards a interface on other box reachable through global routing table ?
5 Replies 5
I dont know about XR/XE but for IOS YES you can config under VRF source of bgp.
gautamanish
Hi MHM
Thanks for your reply
My query is bgp peering from a source ip in vrf to peer ip reachable through global routing table
Under vrf we are using following to import peer IP address
Vrf
Import from default-vrf route-policy
R1-R2
R1 using VRF <X> to connect to R2 using global
R2 dont care about the VRF, VRF is locally known, what is important is
1- R1 VRF can reach the R2
2- R2 can reach R1 VRF LO
with IOS you can use under the IPV4 VRF the BGP update source which is LO which config with VRF <X>
this make BGP using LO VRF <X> to establish BGP session with R2.
are you run only IPV4 or there are other address family ?
thanks , yes we will be doing the same for ipv6 also
Harold Ritter
Hi @gautamanish ,
It is indeed possible, but you need to make sure the global routing table also has a route to the loopback interface sitting in the VRF. Try adding a static route in the global with the loopback interface as the destination.
ip route <loopback interface ip address in the VRF> 255.255.255.255 Loopback X
Also bear in mind that routes advertised via that BGP session will need to be exported from the VRF to the global.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
