ebgp-multi-hop connection
wgranada1
Hi everyone how are things? I have a quick quesiton here. I'm trying to create a ebgp-multihop connection but the problem is it never establishes. I don't have any access-list on the interface so it is wide open, I've been looking at this for a while now so everything looks ok to me. I know I'm missing something but anyways here is my config:
router bgp 60301
neighbor 192.168.50.50 remote-as 64637
neighbor 192.168.50.50 ebgp-multihop 5
neighbor 192.168.50.50 update-source FastEthernet1/15
neighbor 192.168.50.50 version 4
neighbor 192.168.50.50 soft-reconfiguration inbound
neighbor 192.168.50.50 prefix-list from-interim in
neighbor 192.168.50.50 prefix-list to-interm out
when I do a sh ip bgp neigh 192.168.50.50 I see the bgp state as active but not established. I've done a soft clear and clear but nothing as of yet. Thank you in advance!!
23 Replies 23
I appreciate the help...sorry guys I was trying to keep my ip private but I think I'm doing more harm than help so here is it is with the real IPs
MY SIDE:
router bgp 64821
no synchronization
bgp router-id 172.19.103.45
bgp log-neighbor-changes
neighbor 10.128.184.105 remote-as 64637
neighbor 10.128.184.105 ebgp-multihop 5
neighbor 10.128.184.105 update-source FastEthernet1/15
neighbor 10.128.184.105 version 4
neighbor 10.128.184.105 soft-reconfiguration inbound
neighbor 10.128.184.105 prefix-list from-interim in
neighbor 10.128.184.105 prefix-list to-interm out
His side:
router bgp 64637
no synchronization
neighbor 172.19.103.45 remote-as 64821
neighbor 172.19.103.45 ebgp-multihop 5
neighbor 172.19.103.45 update-source Loopback1
neighbor 172.19.103.45 soft-reconfiguration inbound
neighbor 172.19.103.45 prefix-list Routes-from-Futures in
neighbor 172.19.103.45 prefix-list Routes-to-Futures out
no auto-summary
now he told me I'm suppose to be peering with his 10.128.184.105 and inorder for me to get to that peer I need to go through the ethernet connection
My side
interface FastEthernet1/15
ip address 172.19.80.9 255.255.255.252
His side
interface gigethernet 0/1
ip address 172.19.80.10 255.255.255.252
I have routes to his 10.128.184.105
sfschirt4#sh ip route 10.128.184.105
Routing entry for 10.128.184.105/32
Known via "static", distance 1, metric 0
Redistributing via ospf 1
Routing Descriptor Blocks:
* 172.19.80.10
Route metric is 0, traffic share count is 1
and can source ping
sfschirt4#ping 10.128.184.105 source 172.19.80.9
Sending 5, 100-byte ICMP Echos to 10.128.184.105, timeout is 2 seconds:
Packet sent with a source address of 172.19.80.9
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
sorry guys about that
Also when I did run a debug I see the following:
Mar 28 15:29:17.315 UTC: BGP: 10.128.184.105 passive open to 172.19.103.45
*Mar 28 15:29:17.315 UTC: BGP: 10.128.184.105 passive open failed - 172.19.103.45 is not update-source FastEthernet1/15's address (172.19.80.9)
*Mar 28 15:29:17.315 UTC: BGP: 10.128.184.105 remote connection attempt failed, local address 172.19.103.45
*Mar 28 15:29:37.195 UTC: BGP: 10.128.184.105 open active, local address 172.19.80.9
*Mar 28 15:29:37.195 UTC: BGP: 10.128.184.105 open failed: Connection refused by remote host, open active delayed 25365ms (35000ms max, 28% jitter)
Warren,
172.19.103.45 is the address your peer uses. Make sure you use the interface that matches that address as your update-source on your side.
Hi Warran
The 172.19.103.45 address is not assigned to your F1/15 interface. You need to make sure that you have the interface assigned to this address as your update source for this peering.
Martin
I was looking over the config and noticed that I have an internal peering as well that is also using the loopback address as well if I source from the new connection as suggested will that affect what is already there?
router bgp 64821
no synchronization
redistribute ospf 1 match internal external 1 external 2 route-map to-VNET
neighbor VNET peer-group
neighbor VNET remote-as 64820
neighbor VNET update-source FastEthernet1/0
neighbor VNET version 4
neighbor VNET soft-reconfiguration inbound
neighbor VNET prefix-list from-VNET in
neighbor VNET prefix-list to-VNET out
neighbor VNET route-map from-VNET-LOCALPREF in
neighbor VNET route-map to-VNET-PREPEND out
neighbor VNET filter-list 17 out
neighbor SFS-INTERNAL peer-group
neighbor SFS-INTERNAL remote-as 64821
neighbor SFS-INTERNAL update-source Loopback0<-- Already being used
neighbor 172.19.98.50 peer-group VNET
neighbor 172.19.103.30 peer-group SFS-INTERNAL
no auto-summary
Warren,
You can use the loopback interface as the update-source for the eBGP and iBGP session.
YOU GUYS ROCK!!!!! thank you all for helping out sorry about the confusion in the beginning
I see that neighor relationship has been established:
sfschirt4#sh ip bgp neigh 10.128.184.105
BGP neighbor is 10.128.184.105, remote AS 64637, external link
BGP version 4, remote router ID 10.128.184.105
BGP state = Established, up for 00:00:10
YEAH!!!!! thank you agian!!!!!
No Problem Warren
Glad you have it all working now.
The update-source is specific only to that neighbor. It will not affect any other update-source interfaces you have configured under this AS.
