eBGP Peering with Secondary IP of Interface
tckoon
Reason to do so is because the IP is running out, need to additional subnet.
All the ISP is eBGP peering with each other in one VLAN, but due to growing number of ISPs the IP is running out
and new subnet is added as secondary IP in VLAN.
But the peering cannot up because the BGP local IP is alway bind to primary IP, not secondary IP.
Is there way to force it to use secondary IP as source address during BGP peering
R1
interface GigabitEthernet2/0
ip address 100.1.1.1 255.255.255.252 secondary
ip address 10.1.1.1 255.255.255.252
negotiation auto
router bgp 10081
no synchronization
bgp log-neighbor-changes
neighbor 100.1.1.2 remote-as 4818
neighbor 100.1.1.2 update-source GigabitEthernet2/0
no auto-summary
R2
ip address 100.1.1.2 255.255.255.252 secondary
ip address 10.1.1.2 255.255.255.252
negotiation auto
router bgp 4818
no synchronization
neighbor 100.1.1.1 remote-as 10081
neighbor 100.1.1.1 update-source GigabitEthernet2/0
no auto-summary
*Aug 12 22:06:21.331: BGP: 100.1.1.2 open active, local address 10.1.1.1
*Aug 12 22:06:21.423: BGP: 100.1.1.2 read request no-op
*Aug 12 22:06:21.431: BGP: 100.1.1.2 open failed: Connection refused by remote host, open active delayed 23553ms (35000ms max, 60% jitter)
Marwan ALshawi
Try to use a local pbr to nat the primary ip to the secondary one for NGO session to the other end peer use the bellow work around
R1
interface Loopback1
ip address 1.1.1.1 255.255.255.255
ip nat inside
interface FastEthernet0/0
ip address 192.168.1.1 255.255.255.0 secondary
ip address 10.0.0.1 255.255.255.0
ip nat outside
duplex auto
speed auto
router bgp 100
no synchronization
neighbor 192.168.1.2 remote-as 100
no auto-summary
ip local policy route-map bgp
ip nat inside source static 10.0.0.1 192.168.1.1 extendable
ip http server
ip classless
access-list 100 permit tcp any any eq bgp
route-map bgp permit 10
match ip address 100
set interface Loopback1
Marwan ALshawi
By the way if you are going to try it make sure in the pbr acl for bgp to put the destination as the next bgp peer otherwise all your other bgp session will be nated and fail
Good luck
If helpful rate
Marwan ALshawi
Did you try the suggested bgp/pbr workaround ?
Giuseppe Larosa
Hello tckoonp@hp,
I would suggest you  to use two Vlan based subinterfaces instead of secondary address that are not meant to be used for routing purposes as you have seen
I agree that there is impact in doing this, but you can consider the use of native vlan and the fact that main interface can keep the current L3 interface configuration ( I don't like it but it is possible).
If all router ports connect to a switch all is needed is to convert the switch ports to a L2 trunk with native untagged vlan = current Vlan associated to primary addresses + the vlan for the new subnet.
I guess it is possible that the switches are not under your control, if your setup is  in an internet exchange point.
If this is the case, they usually have a secondary VLAN for the peerings and all you need is to connect another GE port to the secondary peering VLAN.
Hope to help
Giuseppe
