ECMP question.
Yahowmy88
Good day,
The following question about ECMP routes, i just don't get how these routes are the correct routes? i'm certain that for routes to satisfy ECMP distance and priority need to be the exact same, i would appreciate your help.
Giuseppe Larosa
Hello Yahowmy88,
do you realize that you are asking about a question on Fortinet Fortigate firewalls in Cisco forums ?
I agree that for a Cisco device the correct answers should be C,D however, Fortinet implementation of static routes is different from the Cisco one.
Fortinet can use not only admin distance with static routes but also the priority concept. Lowest priority is preferred.
All static routes with same admin distance are considered active but only those with lowest priority are used.
Hope to help
Giuseppe
