04-27-2021 02:07 PM
I have 2 Catalyst 9300 L3 Edge switches. I have 1 fiber connection to the ISP with 1 IP address for Internet traffice and a Metro-E for our WAN fiber connection. I have 2 swithces in case of failure. I have the switches cabled, 1 with the Internet connection and 1 with the Metro-E, so all I need to do is change out 1 fiber connection. If I have the port shutdown on the backup switch for the Internet connection will it show an IP address duplication error since the IP address to the ISP is the same? The Metro-E port has a different IP address assigned.
Solved! Go to Solution.
04-27-2021 02:28 PM
as long as the port is configured as 'shut' or 'shutdown' there will be no duplicate address problem.
04-27-2021 02:35 PM
Hello
no issue you will be okay
04-27-2021 02:41 PM
04-27-2021 02:41 PM
04-27-2021 02:28 PM
04-27-2021 02:41 PM
04-27-2021 02:35 PM
Hello
04-27-2021 02:41 PM
