01-25-2013 12:46 AM - edited 03-04-2019 06:50 PM
Is there any way to add a class map entery between two existing entries. In other words, I want to add a class map at position 2 of the follwing list. Is there any way in cisco to do it without deleting the rest of entries ? like sequence number etc ?
policy-map policy-default-autocopp
class class-copp-mcast-v4-data-on-routedPort
police rate 10 pps burst 1 packets conform-action drop exceed-action drop
Here I want to add a custom entry
class class-copp-mcast-v6-data-on-routedPort
class class-copp-icmp-redirect-unreachable
police rate 100 pps burst 10 packets conform-action transmit exceed-action drop
class class-copp-ucast-rpf-fail
class class-copp-vacl-log
police rate 2000 pps burst 1 packets conform-action transmit exceed-action drop
class class-copp-mcast-punt
police rate 1000 pps burst 256 packets conform-action transmit exceed-action drop
class class-copp-mcast-copy
class class-copp-ip-connected
Solved! Go to Solution.
01-25-2013 11:19 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Not that I'm aware of. I do it like you use to need to do it before ACLs supported sequence number, drop and re-add.
01-25-2013 11:19 AM
Disclaimer
Posting
02-04-2013 03:28 AM
Thanks Joseph !
