EEM on ASR1002
Hi ,
Please let me know if EEM ( Embedded Event Manager ) script support on ASR1002 platform , if yes which OS release will support this feature .
Want to use EEM to tshoot intermittent high cpu on ASR1002 .
any suporting document to implement eem and tshoot high cpu on ASR .
Thank you .
Raj
veneet.thakur
Hi Raj,
Yes, the EEM scripts are very much supported in ASR 1000 family, I don't think the support is specifically for any particular IOS-XE release but should be supported for all releases.
Following links should help you more what you are looking for.
http://www.cisco.com/image/gif/paws/116213/116213-trouble-asr-eem-00.pdf
http://www.cisco.com/en/US/docs/ios-xml/ios/eem/configuration/xe-3s/asr1000/eem-overview.html
Hope this helps.
Veneet
