EEM Script for shutdown interface for Packet Drop
network_geek
Level 3
Level 3
Hi All,
I wish to implement EEM Tracking and IP SLA on my IOS XR router. Can anyone please guide me?
The scenario is as follows:
I want to ping the remote link(same network) continuously and if there are a certain number of ICMP packets dropped then I would want to shut the interface.
Thanks in advance.
11 Replies 11
Georg Pauwen
below is a very basic IP SLA that triggers an EEM script in case of failure and success:
track 1 ip sla 1 reachability
interface GigabitEthernet0/0
ip address 192.168.1.1 255.255.255.252
duplex auto
speed auto
media-type rj45
ip sla 1
icmp-echo 192.168.1.2 source-ip 192.168.1.1
threshold 500
timeout 1000
frequency 2
ip sla schedule 1 life forever start-time now
event manager applet SHUT_IF
event track 1 state down
action 1.0 cli command "enable"
action 2.0 cli command "conf t"
action 3.0 cli command "interface GigabitEthernet0/1"
action 4.0 cli command "shut"
action 5.0 cli command "end"
event manager applet UNSHUT_IF
event track 1 state up
action 4.0 cli command "no shut"
Hi George,
Thank you for your reply. If I am correct, the script you have pasted is for IOS-XE. I am looking specifically for IOS-XR. Could you help me with that? Thanks in advance.
I thought it would work on XE...I'll check that. XR doesn't support ICMP jitter, so you can only use ICMP echo...
I can make do with echo only. But any help would be appreciated. I would post exactly my problem later and then we'll see if we can find another way around.
the syntax seems to be different in XR. Below is the IP SLA. There is no applet manager apparently, so this has to be done from within a policy. I am currently looking into this...will get back with you (unless somebody else beats me to it of course...:).
ip sla operation 1
type icmp echo
destination address 192.168.1.2
frequency 2
ip sla schedule operation 1
life forever
start-time now
commit
Jaderson Pessoa
@network_geek Hello,
ip sla 10
icmp-echo 192.168.1.1 source-ip 192.168.1.2
threshold 1000
frequency 5
ip sla schedule 10 life forever start-time now
event manager applet ISP1
event track 10 state down
action 0.5 syslog msg "remote address 192.168.112.1 stopped responding. Shutting down gi0/1"
action 2.0 cli command "configure terminal"
action 3.0 cli command "interface gi 0/1"
action 4.0 cli command "shutdown"
action 6.0 syslog msg "gigabitethernet0/1 is now disabled. It will be re-enabled manually after an expert review."
Jaderson Pessoa
*** Rate All Helpful Responses ***
How is that script different from the one already posted ?
lucasfreitas83
Level 4
Level 4
If not possible monitor event down in tracking or IP SLA, try monitor event logs of router system.
EX:
event manager applet Monitor_DOWN
event syslog occurs 1 pattern "TRACKING-5-STATE: 10 rtr 10 reachability Up->Down"
action 1.0 syslog msg "Track DOWN"
event manager applet Monitor_UP
event syslog occurs 1 pattern "TRACKING-5-STATE: 10 rtr 10 reachability Down->Up"
Other commands equal examples in other posts.
Test and verify correct log on system - show logging and put after 1 pattern " LOGS"
Please rate and mark posts accordingly if you have found any of the information provided useful.
It will hopefully assist others with similar issues in the future.
Best regards,
Lucas Freitas
Hi All,
Just a quick insight into the scenario. I have a router that connects to the switch and through layer 2 I traverse it through multiple switches and at last reaching the other end. The script shared for down might not help me because the link physically stays up and the link in between the switches goes down, hence my initial idea of using ICMP to trigger the script.
I hope now the situation is much more clear and you would be able to provide me with a better solution.
Thanks in advance.
EX:
Best regards,
Lucas Freitas
You need uses IPS SLA with ping, the difference of other solutions is a monitor event log in router.
Configure IP SLA as the above examples.
ip sla 10
threshold 1000
frequency 5
event track 10 state down (change this line per line bellow).
When the router can't ping another side, he puts a log in the system log.
This log probably "TRACKING-5-STATE: 10 rtr 10 reachability Up->Down"
But, verify correct log in router - show log and change string in " "
Best regards,
Lucas Freitas
Georg Pauwen
I have come up with two TCL scripts (attached as zipped files), you need to unzip these and copy them to your flash or disk0 directory (check which one your router uses):
Your IP SLA would look like this:
track 1
type rtr 1 reachability
ip sla operation 1
type icmp echo
frequency 2
life forever
start-time now
commit
You need to configure the below parameters (again, check if your router uses flash0 or disk0 and change that parameter accordingly):
event manager environment _syslog_pattern .*(track 1 state Track_Down)
event manager directory user policy flash0:
event manager policy LINK_DOWN.tcl username eem persist-time 3600
event manager environment _syslog_pattern .*(track 1 state Track_Up)
event manager policy LINK_UP.tcl username eem persist-time 3600
These are the scripts:
Script 1 LINK_DOWN.tcl
::cisco::eem::event_register_syslog pattern {.*track 1 state Track_Down.*} maxrun 80
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
array set arr_einfo [event_reqinfo]
if [catch {cli_open} result] {
error $result $errorInfo
} else {
array set cli1 $result
if [catch {cli_exec $cli1(fd) "enable"} _cli_result] {
error $_cli_result $errorInfo
if [catch {cli_exec $cli1(fd) "conf t"} _cli_result] {
if [catch {cli_exec $cli1(fd) "int Gi0/1"} _cli_result] {
if [catch {cli_exec $cli1(fd) "shut"} _cli_result] {
if [catch {cli_exec $cli1(fd) "commit"} _cli_result] {
if [catch {cli_exec $cli1(fd) "end"} _cli_result] {
# Close open cli before exit.
catch {cli_close $cli1(fd) $cli1(tty_id)} result
Script 2 LINK_UP.tcl
::cisco::eem::event_register_syslog pattern {.*track 1 state Track_Up.*} maxrun 80
} else {
if [catch {cli_exec $cli1(fd) "no shut"} _cli_result] {
