EEM script to generate dummy syslog logs.
KumarMH06540
Need help with EEM script for cisco routers and switches to generate dummy syslog log and sent it periodically to IBM Qradar sys log server.
Due to no activity from the switches and routers, the syslog server is considering the routers and switches as down. so need to send dummy logs periodically.
Please suggest/guide on the same.
the below EEM script would generate a SYSLOG entry once a day:
event manager applet DUMMY_SYSLOG
event timer cron cron-entry "0 0 * * *" maxrun 9999999
action 1.0 cli command "enable"
action 2.0 cli command "send log TEST"
