EF Max Bandwidth
jonathan.magee
What is the maximum recommended EF bandwidth supported on a ASR 1001
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Assuming you intend EF to be treated as LLQ, generally, Cisco recommends you don't allocate more than one third of your bandwidth for your LLQ.  (This Cisco recommends to provide adequate bandwidth for non-LLQ classes.)
If non-LLQ class bandwidth isn't a concern, I would say you can go higher, but as LLQ is often used to minimize any queuing latency and/or jitter, going above about one third risks there being insufficient bandwidth.  Up to about 50% you shouldn't incur too much additional risk, some additional risk up to about two thirds, but above two thirds, you probably want to avoid.
