First of all, thanks to anyone who tries to help and support this question.
We are a starting small company with 3 branches
I was requested to connect the Main branch with the 2 other branches. So I thought the best solution is to get a fast internet connection for each one of the 3 branches (ex. 100mbs) with a static IP address.
And to connect those 2 to the main branch I was advised to get the ASA 5505 for each branch and connect them by creating 2 Secure VPN networks.
So lets say I have the following:
Main Branch:
Public static IP address: 7.7.7.7
Internal NID: 192.168.1.0/24
Server Static IP Address: 192.168.1.1/24
Second branch:
Public Static IP address: 8.8.8.8
Internal NID: 192.168.2.0/24
Server Static IP address: 192.168.2.1/24
Third Branch:
Public Static IP address: 9.9.9.9
Internal NID: 192.168.3.0/24
Server Static IP address: 192.168.3.1/24
Note that the ASA Firewalls will be connected to normal routers provided by the ISP unless its necessary to do otherwise.
So What I'm asking is:
1. Is it possible to do so with these ASA 5505 firewalls?
2. For the main branch, Do I have to have several public IP addresses?
3. Can you please provide a syntax configuration for how those ASA 5505 Firewalls should be configured?
4. Is there a much cheaper way to do this?
Thank you very much for your help
Sincerely,
ARFallaha
