Effect of assigning wrong IP to router interface
ayo_adesanya
What are the possible effects of assigning an invalid address like 172.22.0.0 255.255.255.252 to a router interface. The 1841 router accepted the address. Thanks.
paolo bevilacqua
And why that should be an invalid address in your opinion ?
12 Replies 12
paolo bevilacqua
172.22.0.9 255.255.255.252 should only support 2 addresses i.e: 172.22.0.1 - 172.22.0.2.
I recommend that you go back at studying addresses and netmasks ...
I actually meant to write 172.22.0.0 with mask 255.255.255.252. Thanks
Hello ,
172.22.0.9 255.255.255.252 is a valid address also 172.22.0.10
the network address is 172.22.0.8 and the broadcast is 172.22.0.11
Dan
My mistake. I meant 172.22.0.0 255.255.255.252.
jgraafmans
There is nothing wrong with this IP address. With this mask the IP address is part of a subnet of 4 addresses. 172.22.0.8 - 172.22.0.11 where 172.22.0.8 is the network address and 172.22.0.11 is the broadcast address and are thus not useable. If you connect a PC and give it IP address 172.22.0.10 you should be able to ping 172.22.0.9 successfully.
My mistake. I meant 172.22.0.0 which should support 172.22.0.1 - 172.22.0.2 ordinarily. But 172.22.0.9 was assigned to a router interface. It accepted the address and appears to be okay but since 172.22.0.0.255.255.255.252 should be limited to 172.22.0.1 - 172.22.0.2, could assigning 172.22.0.9 have an effect? I think it should but I've not noticed any direct effect. Also I have ocassional performance issues with the router and I'm wondering if this could be the cause.
Thanks for your time.
That is made to support /31 masks, and save addresses. It's ok to do that if you want.
cadet alain
depends, but e.g if you are using routing protocols like OSPF or EIGRP then you could lose adjacency.
what is your topology?
Regards.
alain.
Could you be a little bit clearer please
Thanks.
Regards.
Alain.
