EIGRP Adjacency flapping, IPv6
techchi
Feb 13 11:52:38.554: %DUAL-5-NBRCHANGE: EIGRP-IPv6 100: Neighbor FE80::2 (Ethernet0/0) is down: holding time expired
*Feb 13 11:52:46.255: %DUAL-5-NBRCHANGE: EIGRP-IPv6 100: Neighbor FE80::1 (Ethernet0/0) is up: new adjacency
*Feb 13 11:52:50.946: %DUAL-5-NBRCHANGE: EIGRP-IPv6 100: Neighbor FE80::2 (Ethernet0/0) is up: new adjacency
*Feb 13 11:53:01.260: %DUAL-5-NBRCHANGE: EIGRP-IPv6 100: Neighbor FE80::1 (Ethernet0/0) is down: holding time expired
*Feb 13 11:53:01.262: EIGRP: Build goodbye tlv for FE80::1
*Feb 13 11:53:05.955: %DUAL-5-NBRCHANGE: EIGRP-IPv6 100: Neighbor FE80::2 (Ethernet0/0) is down: holding time expired
*Feb 13 11:53:27.259: %DUAL-5-NBRCHANGE: EIGRP-IPv6 100: Neighbor FE80::1 (Ethernet0/0) is up: new adjacency
*Feb 13 11:53:32.060: %DUAL-5-NBRCHANGE: EIGRP-IPv6 100: Neighbor FE80::2 (Ethernet0/0) is up: new adjacency
*Feb 13 11:53:42.267: %DUAL-5-NBRCHANGE: EIGRP-IPv6 100: Neighbor FE80::1 (Ethernet0/0) is down: holding time expired
*Feb 13 11:53:42.276: EIGRP: Build goodbye tlv for FE80::1
5 Replies 5
techchi
R2{Eth0/0}-----{Eth2/0}SW1-vlan23{Eth2/1}------{Eth0/0}R3
techchi
In wireshark all I see "Parameters: Peer Termination" is this Frame 116: 104 bytes on wire (832 bits), 104 bytes captured (832 bits) on interface 0
Ethernet II, Src: aa:bb:cc:00:70:00 (aa:bb:cc:00:70:00), Dst: IPv6mcast_0a (33:33:00:00:00:0a)
Internet Protocol Version 6, Src: fe80::3, Dst: ff02::a
0110 .... = Version: 6
.... 1110 0000 .... .... .... .... .... = Traffic class: 0xe0 (DSCP: CS7, ECN: Not-ECT)
.... .... .... 0000 0000 0000 0000 0000 = Flow label: 0x00000
Payload length: 50
Next header: EIGRP (88)
Hop limit: 1
Source: fe80::3
Destination: ff02::a
[Source GeoIP: Unknown]
[Destination GeoIP: Unknown]
Cisco EIGRP
Version: 2
Opcode: Hello (5)
Checksum: 0xec6d [correct]
Flags: 0x00000000
.... .... .... .... .... .... .... ...0 = Init: Not set
.... .... .... .... .... .... .... ..0. = Conditional Receive: Not set
.... .... .... .... .... .... .... .0.. = Restart: Not set
.... .... .... .... .... .... .... 0... = End Of Table: Not set
Sequence: 0
Acknowledge: 0
Virtual Router ID: 0 (Address-Family)
Autonomous System: 100
Type: Parameters (0x0001)
Length: 12
K1: 255
K2: 255
K3: 255
K4: 255
K5: 255
K6: 255
Hold Time: 15
[Expert Info (Note/Response): Peer Termination]
[Peer Termination]
[Severity level: Note]
[Group: Response]
Software Version: EIGRP=14.0, TLV=2.0
Type: Software Version (0x0004)
Length: 8
EIGRP Release: 14.00
EIGRP TLV version: 2.00
Peer Topology ID List
Type: TopologyID List (0x00f5)
Length: 10
TID List Flags: 0x0000
TID List Size: 2
1 TIDs
techchi
Here is the EIGRP Packet debug on R3
grabonlee
Level 4
Level 4
Your attachment R2 Neighbors shows a different interface for the adjacency (E0/1) from the flapping interface (E0/0) and the your topology drawing.
1. R2 Neighbors shows int E0/1 with link-local FE80::1 and not E0/0
2. Can you confirm that all the interfaces on the 2 switches are on Vlan 23, as your diagram only shows vlan 23 for one switch
Can you post the Eigrp neighbor for R3?
It is not clear to me which device generated the log messages in the original post. But a couple of things are clear.
- this device sees 2 neighbors on its Ethernet interface.
- each this device receives a message from a neighbor and attempts to establish a neighbor relationship.
- 15 seconds later the device marks the neighbor as down because of hold time.
- after a short amount of time the cycle repeats.
Can we see from at least one of those neighbors what they think is going on?
Rick
Rick
