no service password-recovery
oaderemi93
I am trying to enable the "no service password-recovery" feature on a Cisco ASR 920 running Cisco IOS XE Software, Version 16.06.03.  The ROMMON version is Version 15.6(1r)S1. The Configuration register is set to 0x2102. But the feature is not still available from the configuration mode (check picture). Can someone provide guidance on this please?
luis_cordova
Hi @oaderemi93,
Maybe the command is hidden.
I suggest you enter the command:
Router(config)#no service password-recovery
   WARNING:
   Executing this command will disable password recovery mechanism.
   Do not execute this command without another plan for
   password recovery.
Are you sure you want to continue? [yes/no]: yes
and check if it was added:
Router#show running-config
Building configuration...
version 12.4
