EIGRP and HSRP support in 851 router
smonteagudo
Eigrp and HSRP are supported in 851 router with advanced security version?
amit-singh
Level 8
Level 8
I tried to serach the feature using feature navigato but it didnot had the 851 router model number. I know that you can configure EIGRP and I saw that in config-guide too.EIGRP is supported and I am pretty sure HSRP is also supported as in advanced security version for 831 router both EIGRP and HSRP is supported.
HTH,
-amit singh
