eigrp default route
ciscoforum
remeber it used to be this command to allow propagate default route into eigrp
router eigr 100
network 10.0.0.0
default information allow
But it seems no longer working. verison 12.3. Thanks
5 Replies 5
Are you sure it isn't supported in 12.3 code? Here's the output from a router running version 12.4. Your syntax is slightly off.
R3(config)#router eigrp 50
R3(config-router)#default-information ?
allowed Allow default information
in Accept default routing information
out Output default routing information
R3(config-router)#default-information allowed ?
R3(config-router)#default-information allowed in
Sundar
let me reword. allow option is still there. but no longer working, the other router just doesn't receive the defaut route.
chris.baird
what command are you using to "push" the default route to the eigrp instance? I believe it would be "default information originate" under the protocol that is sharing with eigrp 100.
hth
"default information originate" is used under OSPF and BGP, not EIGRP. You can use redistribute static on the router holding the default route.
For instance
router eigrp 5
redistribute static
network 10.0.0.0
no auto-summary
ip route 0.0.0.0 0.0.0.0 null0
The command 'default information allow' is to allow or block the default route from being injected by a neighbor router. By default, allow is turned on so it won't show in the config. Similar to the auto-summary / no auto-summary service under EIGRP.
thanks edison!
