EIGRP deny in local lan broadcast network
Binu Steephen
I have three eigrp configured routers A, B , C in a single broad cast LAN.I want to deny router A eigrp peering with router B, need to retain A peering with C. what is the best solution.
A router
no neighbor <B router lan ip> under router eigrp   will work ?
or
how can i deny using the multicase ip address 224.0.0.10 usinng access lis an din which direction i need to apply.
cadet alain
on RTR A : under eigrp process  type neighbour "ip of RTR C" "LAN interface" command
on RTR C: do the same
Then these 2 routers will form an adjacency using unicast and RTR A won't accept multicast hellos from RTR B and so wont form an adjacency with it.
Regards.
Alain.
"deny eigrp any any" on LAN interafce of A and C we need apply with access list inbound, corrcet?
option II
is this ok if we apply "deny eigrp host "C IP" to host A  IP" using inbound ACL on router A lan interafce and respective on C router as well.
Please advise.
A & C need to form EIGRP peering, A doesn't want to peer with B:
Two options:
1) Use unicast EIGRP hellos on A & C by using neighbor statement on both of them.
On A:
router eigrp 100
neighbor
On C:
router eigrp 100
neighbor
2) If you want to use multicast hellos, just tse "deny eigrp any any" in inbound direction on B, so that the hellos coming from A or C are dropped. By doing this, B won't be able to peer with anyone on that LAN interface.
HTH,
Amit
if you want RTR B not to be adjacent with the other 2 routers you can do as I proposed above that is enable unicast hellos on RTR A and RTR C.this way as RTR B is still doing multicast its hellos will be dropped on the 2 other routers which only accept unicast hellos and as it is only listening to multicast hellos it will drop the unicast ones from the other 2.
You could also leave multicast everywhere and filter eigrp packets from Router B inbound with an access-list like you proposed applied on RTR A and C interfaces.
Or like Amit said filter inbound on RTR B eigrp hellos from A and C.
Regards.
Alain.
