EIGRP doesn't consider default network as gateway of last resort
mh.gorjizadeh
Hello Guys
Well i have kind of problem with default route in EIGRP.
I setup int loopback  on core router with calassfull ip address  (192.168.1.1/24 ) and do every then in global config by using
ip default-network 192.168.1.0
set it up as default network .
Finally other routers like branch router see that as default network and you can see in show ip route
Gateway of last resort is not
set
Lines omitted for brevity
D* 192.168.1.0/24 [90/2297856] via 10.1.1.1, 00:05:10, Fastethernet 0/0
but weird thing is that the ((Gateway of last resort is not set)) !!!
what can cause such problem ?
I must admit i use GNS3 and Packet tracer , and it works in packet tracer properly but not in GNS3 .
Thank for your help
Do you have a route to 0.0.0.0 0.0.0.0.0 anywhere? you must have one then redistribute into EIGRP
I used other method which consider some route  as default network ( it can be even a route to loop-back interface) .
Well i just changed the router (in GNS3) and it already works.
Thank you for your help
