Eigrp failover - Need your help
Ashok Kumar
We have two VPN tunnel paths from headquarters to remote site. Now the traffic is going through a path. If we make the wan interface of the primary path as passive, will it switch over to secondary path??? Kindly clarify me,,
Sent from Cisco Technical Support Android App
John Blakley
Technically, if you have 2 paths to the destination in your routing table, you'll roll over to the second path with almost no downtime. This is going to depend on both ends though having two paths. You can see if you have at least 2 paths to the remote site with a "show ip route". If you only see one path in there, you can look at your eigrp topology table to see if it sees 2 paths. "show ip eigrp topology" At a minimum, you'd need two paths listed to the same subnet in the topology table for a quick failover. If you don't and you failover, the router will need to query neighbors for a successor and if it doesn't find one, then you'll blackhole traffic because there will be no route at all.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
