RSTP - Message Age
Juan Urti
Hi all!
Someone knows, in RSTP, when one switch receive a BPDU, how does the switches manipulate the message age timer in RSTP? Does it modify the message age?
Peter Paluch
Hello Juan,
In RSTP, each non-root switch receives a BPDU on its Root Port with the Message Age set to N, N>=0. As a result, the switch itself will send out its own BPDUs with the Message Age set to N+1. A root swich sends its BPDUs with the Message Age set to 0.
Best regards,
Peter
Peter Paluch
Hello Juan,
Best regards,
Peter
Great Answer Peter, it was very useful.
Your answer, allows me to comprend how RSTP solve the Count to Infinity problem.
Thanks!!!!
Peter, really your answer is correct. I have verified with 4 switches and the wireshark.
The topology was a chain with:
SW1 -> SW2 -> SW3 -> SW4  where SW 1 is the root, and i have inspected the bpdu in sense SW3 (DP) to SW4 (RP).
SW1 send his bpdu with Message Age = 0
SW2 send his bpdu with Message Age = 1
SW3 send his bpdu with Message Age = 2
Thanks Again!
