Eigrp INIT state when changing
vmorozan96
Hi!
I have a problem with eigrp and dmvpn.
I have a router used as hub for dmvpn. It has a /24 mask on the tunnel interface, but due to continuosly increasing network, I need to make the mask /22.
So I prepared some new spokes.
So at first I had 1.1.49.1/24 as ip for the tunnel on the hub and spokes from .2 to .254.
And now I have some spokes with 1.1.48.x/22 and also changed mask on hub and other spokes to /22 but now it seems like only 1.1.48.x spokes are working, and the ones with .49 give the error Eigrp stuck in init state.
Does anyone know what the problem could be?
Martin L
what about DMVPN sessions and IP NHRP? you may want to reset sessions and clear ip nhrp.  do you have tunnels without security protocols like IPSec ?
we probably need more details like config of hub and 2 spokes (working and not)
Regards, ML
**Please Rate All Helpful Responses **
