EIGRP IP summary
s.kanth
Level 4
Level 4
Hi All,
I have a doubt about " IP summary " command ,that is configured under interface section....
Assume , 192.168.1.1 ip is configured for Gi0/1 interface and advertized under EIGRP but "10.10.10.0/24" NOT configured under any interface but it is added into Tunnel 11 and want to advertise with summary address. Does it work ?
----------------SAMPLE Config----------------------
int gi0/1
router eigrp 1
network 192.168.1.0
Int tunnel 11
ip summary address eigrp 1 10.10.10.1 255.255.255.0
Thanks in Adv.
Sri
Sri
Using eigrp stub connected summary is an important detail that was not in the original post. And as you have found out it does have an important effect on routing behavior of EIGRP. When you configure a router as eigrp stub you are instructing the router that it is not to act as a transit router. This is the reason why the EIGRP neighbors do not send querry packets to a stub, because the stub router is not transit. This means that there are not any remote routes reachable through the stub. Even though the stub router has learned the 10.10.10.0 network it will not advertise it while it is a stub router. And if you remote the eigrp stub connected sumary then the router does advertise (and summarize) the network.
Rick
Rick
7 Replies 7
Richard Burts
Sri
There are a few small issues in the config that you post but the answer to your question is that yes the summary address configured on the tunnel could work.
Here is what it would take for it to work:
- there is a small syntax issue in your summary command and it should be this
ip summary address eigrp 1 10.10.10.0 255.255.255.0
(note the fourth octet of the address which should be 0 and not 1)
- the tunnel does not have an IP address configured. Without an IP address on the tunnel interface the tunnel will not carry IP traffic.
- when you configure an IP address on the tunnel then you also need to put a network statement into EIGRP that includes the tunnel into the EIGRP processing.
- some subnet of 10.10.10.0 must be present in the routing table if EIGRP is to summarize it.
With these things then the EIGRP summary should work.
Rick
Rick
Sorry Rick for sytax error...
Here is my config
int gi0/1
router eigrp 1
network 192.168.1.0
network 172.16.30.0
no auto
Int tunnel 11
ip address 172.16.30.1 255.255.255.0
10.10.10.0/24 network coming from down stream switch ( eigrp stub configured due to SIA issue). Yes, this route is in the routing table.
I added 10.10.10.0/24 network in summary route ,but it is not seen in other distrubution switch. ( when i remove stub,it work !. ) .  I am missing somthing here .please help
Thanks in Adv.
Sri
Sri
Rick
Rick
Rick. I understand.
One more question !
If  "eigrp stub" configured on router,  the router advertises Connected and Summary routes..
But if we have "eigrp stub connected summary" ,, is the same as "eigrp stub"?
Sri
Sri
When you configure eigrp stub there are several optional paramters that you might configure (including receive-only and static). eigrp stub connected summary are the defaults and are the same as eigrp stub.
This link has some helpful information about eigrp stub
http://www.cisco.com/en/US/docs/ios/12_0s/feature/guide/eigrpstb.html
Rick
Rick
Gone through same doc and had a doubt 🙂 .. i am now clear . Thanks you very much Rich - Sri
Sri
I am glad that you are now clear about eigrp stub and that my responses were helpful. Thank you for using the rating system to mark the question as answered. This will be useful to other readers of the forum.
Rick
Rick
