EIGRP-IPv4 problem
vanman031
I Keep Getting this Error on Router 1 and 3 ?? "DUAL-6-NBRINFO: EIGRP-IPv4 blocked: not on common subnet" Any Ideas ? I am still able to ping though all routers and pc's?
Router 1 config
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
no ip domain lookup
ip cef
license udi pid CISCO1941/K9 sn FTX1722805X
license boot module c1900 technology-package securityk9_npe
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/1
 duplex auto
 speed auto
interface Serial0/0/0
 ip address 10.1.1.1 255.255.255.252
 clock rate 64000
interface Serial0/0/1
 no ip address
 shutdown
router eigrp 99
 network 10.1.1.0 0.0.0.3
 network 192.168.1.0
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
end
Router 2 config
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
no ip domain lookup
ip cef
license udi pid CISCO1941/K9 sn FTX1722806F
redundancy
interface Loopback0
 ip address 192.168.2.1 255.255.255.0
 no ip address
 shutdown
 no ip address
 shutdown
 duplex auto
 speed auto
 no ip address
 shutdown
 duplex auto
 speed auto
 ip address 10.1.1.2 255.255.255.252
 ip address 10.2.2.2 255.255.255.252
 clock rate 64000
router eigrp 99
 network 10.2.2.0 0.0.0.3
 network 192.168.2.0
no ip http server
control-plane
line con 0
line aux 0
line 2
 no exec
 transport input all
 stopbits 1
line vty 0 4
 login
 transport input all
end
Router 3 config
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
no ip domain lookup
ip cef
license udi pid CISCO1941/K9 sn FTX17228066
redundancy
 no ip address
 shutdown
 no ip address
 shutdown
 duplex auto
 speed auto
 ip address 192.168.3.1 255.255.255.0
 duplex auto
 speed auto
 no ip address
 shutdown
 clock rate 2000000
 ip address 10.2.2.1 255.255.255.252
router eigrp 99
 network 192.168.3.0
no ip http server
control-plane
line con 0
 logging synchronous
line aux 0
line 2
 no exec
 transport input all
 stopbits 1
line vty 0 4
 login
 transport input all
end
Richard Burts
Please provide information about how the routers are connected. The output of show cdp neighbor from each router would be helpful. Without knowing that we can only make assumptions and that is not the optimum way to solve problems.
The configs suggest that R1 should be connected to Serial0/0/0 of R2. My guess at this point is that R1 is actually connected to Serial0/0/1.
Rick
Rick
