My CISCO 887 can't run the configuration after the reload.
emiliodehesa
I configured my CISCO887VA-K9 but after the reload, no configuration is in the router. I tried to configured only the hostname but the issue persists.
Router(config)#hostname PRUEBA
PRUEBA(config)#
PRUEBA#wr
*Oct  1 09:18:09.212: %SYS-5-CONFIG_I: Configured from console by console
Building configuration...
[OK]
PRUEBA#reload
Proceed with reload? [confirm]y
Would you like to enter the initial configuration dialog? [yes/no]: n
Router>
5 Replies 5
adamtodd16
Level 3
Level 3
Run "show version" and check your config register (last line). Chances are it is going to say:
Configuration register is 0x2142
Assuming that it does. Run the following commands:
configure t
config-register 0x2102
end
wr
Check show ver again and ensure register is set correctly. Load your config and reload.
Thanks!! That's work and I can configure the router.
Regards!
Happy to hear it! Don't forget to mark answers as correct / rate useful posts.
Thomas Johnston
I've seen this before one other time and it ended up being bad NVRAM. If you do a "show startup-config" does the startup-config display? Adams suggestion is the most likely answer though.
The issue was the register :)
Regards!
