EIGRP issue using VRF on 3750
ktwaddell
I am in the Lab playing with VRF, got it to work when the switchport itself is a no switchport with IP address, however if I stick the Wan connecting interface into a vlan EIGRP wont create a Neighborship though I can ping it under that VRF.
interface FastEthernet1/0/1
description WAN interconnection
switchport access vlan 5
router eigrp 90
address-family ipv4 vrf NHSS
  network 10.202.128.0 0.0.31.255
  passive-interface default
  no passive-interface FastEthernet1/0/1
  autonomous-system 90
exit-address-family
interface Vlan5
ip vrf forwarding NHSS
ip address 10.202.128.200 255.255.255.0
switch-x#ping vrf NHSS 10.202.128.12
Sending 5, 100-byte ICMP Echos to 10.202.128.12, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/8 ms
switch-x#
switch-x#sh ip eigrp vrf NHSS ne
EIGRP-IPv4 Neighbors for AS(90) VRF(NHSS)
switch-x#
So does anyone know why I cant neighbour 10.202.128.12 now that f1/0/1 is a switchport and in a vlan?
Kev
Hi Kevin,
This starts to look like an IOS bug. Can you perhaps try to totally remove the entire EIGRP configuration and configure it completely anew? Avoid configuring the passive interfaces at this point. In addition, can you assign the "global" EIGRP process a different AS number than the ASN 90 for the NHSS VRF EIGRP?
I assume that interface Vlan5 reports as "up, line protocol up" - a silly question considering the fact that you can ping the other party but nevertheless - let's check it.
Best regards,
Peter
12 Replies 12
Peter Paluch
Hi Kev,
You have passive-interface default in your EIGRP VRF configuration, and the IP interface through which the EIGRP VRF NHSS tries to establish adjacencies is interface Vlan5. However, you did not declare that interface as non-passive. You need to enter the following commands:
router eigrp 90
no passive-interface vlan5
end
Making a switchport (i.e. a Layer2 interface) a non-passive interface will have no effect. The passive/non-passive interface configuration is intended for and applies only to Layer3 interfaces.
Try it out.
Best regards,
Peter
2 things
1st, Of course!!!!!!!!!! that makes alot of sense and cant believe i missed it (the no passive f1/0/1 is from when the port was set to no switchport)
2nd, sadly it didn't work, though I will be keeping it in as I think you are right.
Kev
Hello Kev,
So you are saying that despite using the no passive-interface vlan5 you were not successful in bringing the EIGRP adjacency up? Hmmm...
First, make sure that the Fa1/0/1 is properly configured as a static access port:
  switchport ! Depending on your platform, this command may not be accepted
  switchport mode access
  spanning-tree portfast ! Use this only if the port is not connected to another switch
Second, can you try running the show ip eigrp vrf NHSS interface and post the output here? We should be seeing the interface Vlan5 in the output.
Third, let's see if the debugs can help us here. Try running the debug eigrp packet hello and see if any Hello packets are being sent and received.
I am sure this is something trivial, it's just we are not seeing it Oh, by the way, can you describe your testing topology, i.e. what are the devices you're experimenting with, what are the IOS versions and how are they exactly interconnected?
Best regards,
Peter
I had also missed out the switchport mode access, but again still not working.
srr-queue bandwidth share 10 10 60 20
priority-queue out
mls qos trust dscp
auto qos voip trust
switch-x#sh ip eigrp vrf NHSS interfaces
EIGRP-IPv4 Interfaces for AS(90) VRF(NHSS)
                        Xmit Queue   Mean   Pacing Time   Multicast    Pending
Interface        Peers  Un/Reliable  SRTT   Un/Reliable   Flow Timer   Routes
switch-x#
I have all these debugs on and not showing anything.
switch-x#sh debugging
VRF:
  VRF Selection debugging is on
EIGRP:
  Packet debugging is on
  Route Event debugging is on
  Neighbors debugging is on
EIGRP-IPv4: Address-Family:
router eigrp 90
  no passive-interface Vlan5
  eigrp router-id 10.202.128.200
exit-address-family
I can still ping the other switch under vrf NHSS.
Kevin
Kevin,
Notice that the interface Vlan5 is still not listed in the show ip eigrp vrf NHSS interface output. Until it is missing, EIGRP won't be using it.
Can I suggest a blind experiment? I have tested this on a 2691 IOS, and strangely enough, the passive-interface command was not added to the address-family ipv4 stanza but rather to the "global" level of the EIGRP configuration. Can you try to move all the passive interface configuration to the global level?
Best regards,
Peter
Hi Peter,
Yeah I noticed that this morning as well.
ok I just removed all the passive-interface commands at the moment, but still no neighbour or vlan 5 under the interfaces
router eigrp 90
exit-address-family
I am a lost as to why at the moment!!
Kev
Hello Kev,
Do you believe you could post the entire configuration? And what is the platform once more? Is it a 3750 or something? And the IOS version?
Best regards,
Peter
of course mate, here you go (left out un-used ports config), its a 3750v2 on 122-52.SE
switch-x#sh runn
Building configuration...
Current configuration : 10003 bytes
version 12.2
no service pad
hostname switch-x
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c3750v2-48ps
system mtu routing 1500
authentication mac-move permit
ip subnet-zero
ip routing
ip vrf NHSS
description Salford VRF
rd 65000:1
ip vrf SRFT
description Royal VRF
rd 65000:2
mls qos map policed-dscp  24 26 46 to 0
mls qos map policed-dscp  0 10 18 to 8
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue input bandwidth 90 10
mls qos srr-queue input threshold 1 8 16
mls qos srr-queue input threshold 2 34 66
mls qos srr-queue input buffers 67 33
mls qos srr-queue input cos-map queue 1 threshold 2 1
mls qos srr-queue input cos-map queue 1 threshold 3 0
mls qos srr-queue input cos-map queue 2 threshold 1 2
mls qos srr-queue input cos-map queue 2 threshold 2 4 6 7
mls qos srr-queue input cos-map queue 2 threshold 3 3 5
mls qos srr-queue input dscp-map queue 1 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue input dscp-map queue 1 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue input dscp-map queue 1 threshold 3 32
mls qos srr-queue input dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue input dscp-map queue 2 threshold 2 33 34 35 36 37 38 39 48
mls qos srr-queue input dscp-map queue 2 threshold 2 49 50 51 52 53 54 55 56
mls qos srr-queue input dscp-map queue 2 threshold 2 57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue input dscp-map queue 2 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 3 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 2 4
mls qos srr-queue output cos-map queue 4 threshold 2 1
mls qos srr-queue output cos-map queue 4 threshold 3 0
mls qos srr-queue output dscp-map queue 1 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 3 threshold 3 32 33 34 35 36 37 38 39
mls qos srr-queue output dscp-map queue 4 threshold 1 8
mls qos srr-queue output dscp-map queue 4 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue output dscp-map queue 4 threshold 3 0 1 2 3 4 5 6 7
mls qos queue-set output 1 threshold 1 138 138 92 138
mls qos queue-set output 1 threshold 2 138 138 92 400
mls qos queue-set output 1 threshold 3 36 77 100 318
mls qos queue-set output 1 threshold 4 20 50 67 400
mls qos queue-set output 2 threshold 1 149 149 100 149
mls qos queue-set output 2 threshold 2 118 118 100 235
mls qos queue-set output 2 threshold 3 41 68 100 272
mls qos queue-set output 2 threshold 4 42 72 100 242
mls qos queue-set output 1 buffers 10 10 26 54
mls qos queue-set output 2 buffers 16 6 17 61
mls qos
crypto pki trustpoint TP-self-signed-4188889088
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4188889088
revocation-check none
rsakeypair TP-self-signed-4188889088
crypto pki certificate chain TP-self-signed-4188889088
certificate self-signed 01
  30820241 308201AA A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 34313838 38383930 3838301E 170D3933 30333031 30303031
  32345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D34 31383838
  38393038 3830819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100C237 2437BD69 D7DAAEF3 9D23DF13 514207ED A4AC234F 32BFCBF7 51D88497
  52B6159D 8D273229 AEC8EF38 1E9A215F 2F90DC9A 973C01AC F3151B1A 98EA357E
  E1A86BEE BA8055E2 257CCFC3 C44DA505 B4CA8B5C D6F9050B 16BAA092 292A3141
  6C9933C8 BFC9411A DFF5309A 620E368A 53FCF533 9E5B0402 E180F442 0E6A3555
  B9450203 010001A3 69306730 0F060355 1D130101 FF040530 030101FF 30140603
  551D1104 0D300B82 09737769 7463682D 782E301F 0603551D 23041830 16801430
  48AF3CD8 CA06133D 9C9B55E4 5B1F38E9 E8C66730 1D060355 1D0E0416 04143048
  AF3CD8CA 06133D9C 9B55E45B 1F38E9E8 C667300D 06092A86 4886F70D 01010405
  00038181 00AE74C3 8EC33C3F CFF7D4CC A16F378A 3E2CC973 FDC4C8F9 86CD8694
  7F9C72AE 2724A827 08A93DEB 3CF1871A 39B3F5E5 45A37338 AB3A3E6A 61857D33
  05CE0793 FB14F8C0 7431ADA7 9C437DA5 960B18BC 4E63DDB9 EF92E7FD 1E1525B4
  F403C1E9 FA5F2510 2A7C5EA0 C9D79AC4 99F15A27 7E357737 57C39B40 CFD979C1
  04A63802 9D
  quit
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
class-map match-all AUTOQOS_VOIP_DATA_CLASS
match ip dscp ef
class-map match-all AUTOQOS_DEFAULT_CLASS
match access-group name AUTOQOS-ACL-DEFAULT
class-map match-all AUTOQOS_VOIP_SIGNAL_CLASS
match ip dscp cs3
class-map match-all AutoQoS-VoIP-RTP-Trust
match ip dscp ef
class-map match-all AutoQoS-VoIP-Control-Trust
match ip dscp cs3  af31
policy-map AUTOQOS-SRND4-CISCOPHONE-POLICY
class AUTOQOS_VOIP_DATA_CLASS
  set dscp ef
  police 128000 8000 exceed-action policed-dscp-transmit
class AUTOQOS_VOIP_SIGNAL_CLASS
  set dscp cs3
  police 32000 8000 exceed-action policed-dscp-transmit
class AUTOQOS_DEFAULT_CLASS
  set dscp default
  police 10000000 8000 exceed-action policed-dscp-transmit
policy-map AutoQoS-Police-CiscoPhone
class AutoQoS-VoIP-RTP-Trust
  set dscp ef
  police 320000 8000 exceed-action policed-dscp-transmit
class AutoQoS-VoIP-Control-Trust
  set dscp cs3
interface Loopback0
ip vrf forwarding SRFT
ip address 192.168.95.1 255.255.255.255
description Salford Routed Subnet
priority-queue out
mls qos trust dscp
auto qos voip trust
interface FastEthernet1/0/2
no switchport
bandwidth 100000
ip address 192.168.94.1 255.255.255.0
ip ospf authentication message-digest
ip ospf message-digest-key 1 md5 srft
ip ospf network broadcast
ip ospf dead-interval minimal hello-multiplier 3
priority-queue out
mls qos trust cos
auto qos voip trust
interface FastEthernet1/0/3
interface FastEthernet1/0/46
switchport mode trunk
interface FastEthernet1/0/47
description Salford Port
switchport access vlan 2
switchport voice vlan 3
priority-queue out
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
service-policy input AutoQoS-Police-CiscoPhone
interface FastEthernet1/0/48
description SRFT Port
switchport access vlan 101
switchport voice vlan 102
priority-queue out
mls qos trust cos
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface Vlan1
no ip address
shutdown
interface Vlan2
description Salford Data VLAN
ip address 10.202.146.1 255.255.255.128
interface Vlan3
description Salford Voice VLAN
ip address 10.202.146.129 255.255.255.128
interface Vlan5
interface Vlan101
description SRFT Data VLAN
ip address 192.168.64.254 255.255.255.0
interface Vlan102
description SRFT Voice VLAN
ip address 192.168.65.254 255.255.255.0
router eigrp 90
exit-address-family
router ospf 1 vrf SRFT
router-id 192.168.94.1
log-adjacency-changes
auto-cost reference-bandwidth 10000
area 0 authentication message-digest
network 192.168.64.0 0.0.31.255 area 0
ip classless
ip http server
ip http secure-server
ip access-list extended AUTOQOS-ACL-DEFAULT
permit ip any any
ip sla enable reaction-alerts
line con 0
line vty 0 4
login
line vty 5 15
login
end
Kev
Hi Kevin,
Best regards,
Peter
Morning,
Ok I took a copy of the config, wri era and reloaded.
Pasted the config back on and is now working
Also need to note that I had switched off the other EIGRP switch without saving the config, so had to reconfig that as well, but I do think it was the VRF switch.
Thanks for all your help Peter
Cheers
Kevin
Hi Kev,
Thanks for keeping us informed Well, I don't like when things start working miracuously after reload, but... well. We all know about software bugs.
It has been a pleasure!
Best regards,
Peter
Yeah I know what you mean, I have missed out the passive interfaces, so just putting that back in now and see what happens.
Thanks Again
Kev
