Eigrp Load Balancing
shams_ejaz
Hello All,
We are planning to do Eigrp load balancing between three locations
Previously we have direct connection between location1 PPP via DDN line T1 128kbps and location2
We are using Cisco 1721 With Eigrp protocol redistribution of Rip V2
Now we want to connect
Location1 to Location2
And Location2 to location3
And location 3 to location1
In triangle shape for the purpose of load balancing and failover because location1 is connected to data center and location 2 is connected to other locations.
Location1 Cisco 1721 Configuration
interface FastEthernet0
ip address 192.168.100.101 255.255.252.0
speed auto
Interface Serial 0
Bandwidth 128
Ip address 192.168.50.253 255.255.255.248
Encapsulation ppp
Description Connected to location 2
Interface Serial 1
Bandwidth 128
Ip address 192.168.60.253 255.255.255.248
Encapsulation ppp
Description Connected to location 3
Router eigrp 1
Network 192.168.100.0
Network 192.168.50.0
Network 192.168.60.0
No auto-summary
No eigrp log-neighbor-changes
ip classless
Location2 Cisco 1721 Configuration
ip address 192.168.50.1 255.255.255.128
speed auto
Interface Serial 0
Bandwidth 128
Ip address 192.168.50.254 255.255.255.248
Encapsulation ppp
Description Connected to location1
Interface Serial 1
Bandwidth 128
Ip address 192.168.60.252 255.255.255.248
Encapsulation ppp
Router eigrp 1
No auto-summary
ip classless
Location3 Cisco 1721 Configuration
ip address 192.168.60.1 255.255.255.128
speed auto
Interface Serial 0
Bandwidth 128
Ip address 192.168.60.254 255.255.255.248
Encapsulation ppp
Interface Serial 1
Bandwidth 128
Ip address 192.168.50.252 255.255.255.248
Encapsulation ppp
Router eigrp 1
No auto-summary
ip classless
All these links will be DDN line T1 128kbps
How does this can work and what will be router configuration to make load balancing
As I know that eigrp can do unequle cost load balancing. so Please me help
As I do not have the links online so I cannot do testing
Shams
zubairjalal
Hi.
You need to give the variance command under Router eigrp 1.
It should be like this.
Router eigrp 1
variance 20
--Pls rate if this helps--
Kindly;i have to know why u have using variance command under the eigrp & why u have give 20 for the variance
10xs
By-default EIGRP does equal-cost path load-balancing upto 4 equal cost paths. Here in this case if you dont use "maximum-paths" command under the EIGRP configuration it will take only one path into account. If you want EIGRP to do equal cost-path load-balancing you can use maximu-paths command to set the paths to it.
We use " Varience " command under the EIGRP process to make it do the un-equal cost path load-balancing. When we have the varience factor under the EIGRP process like "20 " in this case, the feasible distance or the metric will be multiplied with the varience factor. The paths/routes with the metric less than resulted value of the above calculation will all become eligible to forward the packets to the destination using the different un-equal cost path routes.
The fesaibility condition should be met in order to do the equal-path load-balancing.
HTH,
-amit singh
hi ali,
variance command will halp you to include the number of available path to the same destination in to the routing table... here is the good example of the variance...
lets assume that you have various path with the cost of 2,4,7 and 9. (this cost vlaues are just for simplified the explanation) now as per the rule routing table include only the best path in routing table it means only the lowest cost path towards the destination will appear in to the routing table... so here path with the cost of 2 is the lowest cost path towards the destination so there will be only the path with cost of 2 will appear in the routing table... here you have various cost path connecected to the destination but because of limitation you will utilize only single path which is best path... but now you want to go for the loadbalancing or you can say you want to utilize your all the path... now variance come into the picture... now i will explain you the variance with different vlue so you will have proper idea of the VARIANCE command...
VARIANCE with the value of 3...
here first of all take lower cost path...
here in our case lower cost path is 2...
now multiply lower cost path with the variance vlaue which we are going to use in this case variance is 3... therefor 2x3=6
now this six indicate that path with the cost 6 or less then cost 6 only will appear in to the routing table... so now we have two path with the cost less then 6...and they are path with cost 2 and 4
if you use variance with the value 3... then only path with the cost of 2 and 4 will apear in the routing table...
VARIANCE with the value of 4...
total number of path in routing table= lowest cost x variance... here 2x4=8
here we have three path whose cost is less then 8 and they are 2,4 and 7...
now here we have three path in routing table in order to loadbalance... whereas in early case we have only two path for loadbalancing in routing table...
if you use variance with the value 4... then only path with the cost of 2,4 and 7 will apear in the routing table...
now Variance with value 5...
here we have 2x5=10 so now we have all four path with cost 2,4,7 and 9 will appear in routing table and we can have load balancing on all four path...
so just remember that variance is the value which is multiply with the lowest past cost availalbe among the multiple path... and routing table include only the path wich the cost wichi is equal to or less then the multiplication of the variance and lowest cost path...
hope this will help you to clear the idea of variance...
rate this post if it helps
regards
Devang
