EIGRP log Query
Vijay Bhargav
HI All,
I am getting the below error in my core devices. i wanted to know what exactly the value 520 mean in the below syslog
.Jun 16 16:12:20.419: %DUAL-5-NBRCHANGE: EIGRP-IPv4:(520) 10: Neighbor X.X.X.X (Vlan50) is down: holding time expired
.Jun 16 16:12:20.447: %DUAL-5-NBRCHANGE: EIGRP-IPv4:(520) 10: Neighbor X.X.X.X (Vlan50) is down: holding time expired
.Jun 16 16:12:20.587: %DUAL-5-NBRCHANGE: EIGRP-IPv4:(520) 10: Neighbor X.X.X.X (Vlan50) is up: new adjacency
.Jun 16 16:12:20.795: %DUAL-5-NBRCHANGE: EIGRP-IPv4:(520) 10: Neighbor X.X.X.X (Port-channel1) is down: Interface PEER-TERMINATION received
.Jun 16 16:12:20.847: %DUAL-5-NBRCHANGE: EIGRP-IPv4:(520) 10: Neighbor X.X.X.X (Port-channel1) is up: new adjacency
.Jun 16 16:16:14.584: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/37, changed state to down
regards,
Vijay bhargav.R
6 Replies 6
cadet alain
I think this is the AS number but I'm not 100% sure.
Alain
HI Alain,
AS number is 10, which is displayed on the log as well
regards,
VB
yep you're correct, some new pair of glasses couldn't hurt for me
Alain
Samil Lama
Hello Vijay,
The "(520)" is the EIGRP DUAL Topology Database Table ID. It comes from a C struct called ddbtype_ that contains a member called ddb_name with a type of char and a length set by a #define that's currently 32. (for IPv4)
A comment on the ddb_name field definition in the struct says: "Name of protocol specific user of ddb".
A "ddb" is a DUAL Descriptor Block. It could be affected by the PDM (Protocol Dependent Module).
The structure of this message is:
LOG: EIGRP-ddb_name:(tableid) as_id: Neighbor address (interface)
In the case of %DUAL-5-NBRCHANGE: EIGRP-IPv4:(520) 10: Neighbor X.X.X.X (Port-channel1)
ddb_name- IPv4
tableid- internal ID for the RIB (520)
as_id- autonomous system ID (10)
address- IP address of the neighbor (X.X.X.X)
interface- Name of the interface (Port-channel-1)
This information comes from a personal research.
Regards.
Please don't forget to rate helpful posts.
I believe you deserve +5 for these great infos.
Alain
Hello Cadet,
Thanks for your rating.
Regards.
