Eigrp metric count
feroz syed
Level 3
Level 3
hi,
All router running default eigrp configuration, Router 3 has 2 successor to reach r2 loop (10.1.102.2),and it both FD is 2681856, how it got 2 successor becoz  from router3 se 1/1 has two hop to reach r2 loop and from se 1/0 has only one hop. Your suggestion plz.
R3#sh ip eigrp topology 10.1.102.0/29
IP-EIGRP (AS 100): Topology entry for 10.1.102.0/29
  State is Passive, Query origin flag is 1, 2 Successor(s), FD is 2681856
  Routing Descriptor Blocks:
  10.1.103.1 (Serial1/1), from 10.1.103.1, Send flag is 0x0
      Composite metric is (2681856/2169856), Route is Internal
      Vector metric:
        Minimum bandwidth is 1544 Kbit
        Total delay is 40000 microseconds
        Reliability is 255/255
        Load is 1/255
        Minimum MTU is 1500
        Hop count is 1
  10.1.203.2 (Serial1/0), from 10.1.203.2, Send flag is 0x0
      Vector metric:
        Load is 1/255
        Minimum MTU is 1500
        Hop count is 1
2 Accepted Solutions
waqas younas
Dear All see the result below. Hopefully confusions are cleared.Goodluck.
      Vector metric:
        Load is 1/255
        Minimum MTU is 1500
        Hop count is 1
      Vector metric:
        Load is 1/255
        Minimum MTU is 1500
        Hop count is 1
REGARDS
WAQAS YOUNAS
CCIE#27815
Routing&Switching
Service Provider
Regards Waqas Younas CCIEx2 #27815 (Routing and Switching) (Service Provider) Contact for Online Training
R2 does not "own" the subnet. It is owned by both R1 and R2 so they both advertise it directly to R3.
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
Please rate helpful posts.
daniel.dib
Level 7
Level 7
The route you are looking at is the subnet connecting R1 and R2 (10.1.102.0/29). Both R1 and R2 are directly connected to this so R3 gets the same route from both of them with the same metric.
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
But Router 3 has directly connected to R2 (R2-->R2 20000+20000)so it should be a successor, how it select second successor by going from R3-->R1-->R2 (20000+20000+20000).
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
waqas younas
      Vector metric:
        Load is 1/255
        Minimum MTU is 1500
        Hop count is 1
      Vector metric:
        Load is 1/255
        Minimum MTU is 1500
        Hop count is 1
REGARDS
WAQAS YOUNAS
CCIE#27815
Routing&Switching
Service Provider
