EIGRP network command
email2vm
R0
interface Serial0/3/0
ip address 10.1.24.1 255.255.255.252
clock rate 64000
interface Serial0/3/1
ip address 10.1.34.1 255.255.255.252
clock rate 64000
interface Vlan1
no ip address
shutdown
router eigrp 25
network 10.1.34.1 0.0.0.0
network 10.1.24.1 0.0.0.0
network 172.16.0.0
auto-summary
R1
interface FastEthernet0/0
ip address 10.1.2.1 255.255.255.0
duplex auto
speed auto
ip address 10.1.34.2 255.255.255.252
router eigrp 25
network 10.1.34.2 0.0.0.0
network 10.1.2.0 0.0.0.255
auto-summary
R2
ip address 10.1.2.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.1.25.2 255.255.255.0
duplex auto
speed auto
ip address 10.1.24.2 255.255.255.252
router eigrp 25
network 10.1.24.2 0.0.0.0
auto-summary
Now thank you for your patience since you are reading this now after going through all my network diagram.
R2 Routes
     10.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
C       10.1.2.0/24 is directly connected, FastEthernet0/0
C       10.1.24.0/30 is directly connected, Serial0/3/0
C       10.1.25.0/24 is directly connected, FastEthernet0/1
D       10.1.34.0/30 [90/2172416] via 10.1.2.1, 00:24:47, FastEthernet0/0  <-------why this is not 10.0.0.0/8
D    172.16.0.0/16 [90/2297856] via 10.1.24.1, 00:21:11, Serial0/3/0
Question: Please let me know
1> D route is not summarized to 10.0.0.0/8 as eigrp is known for auto-summarizaing to classful network
2> Please let me know if you have any doc which describes exact explanation of the network command
Thanks in advance
Nagaraja Thanthry
The auto-summary feature kicks in only when you are traversing different
major networks. EIGRP supports VLSM natively. So, it will not summarize when
you are using the same major network everywhere.
http://www.cisco.com/en/US/docs/ios/iproute_eigrp/command/reference/ire_i1.h
tml#wp1035205
Hope this helps.
NT
And as you can see in
case, it does summarize to 172.16.0.0/16 when crossing a major network border (received via 10.1.24.1).
See also http://www.cisco.com/en/US/tech/tk365/technologies_white_paper09186a0080094cb7.shtml#auto
for an explanation.
BR,
Milan
hmmm.....this makes sense...thank you very much
Ravindra,
Regarding the network command itself: the network command essentially specifies a range of addresses, for example:
network 10.0.0.0 = a range of addresses from 10.0.0.0 to 10.255.255.255
network 172.16.0.64 0.0.0.31 = a range of addresses from 172.16.0.64 to 172.16.0.95
network 192.168.1.21 0.0.0.0 = a range of a single address, 192.168.1.21
Now, if any of your interfaces' IP address falls into any of these ranges specified by network commands then that particular interface will be added to the routing protocol and its real subnet/mask will be advertised to other routers. Note that the mask or the address specified in the network command itself is not advertised - its only purpose is to select an interface on which a particular routing protocol shall be activated. It may be confusing but it is the way it is. For example, if my interface is configured as 192.168.1.21/28 then I can include it into a routing protocol using the command network 192.168.1.21 0.0.0.0 and the router will subsequently advertise the network 192.168.1.16/255.255.255.248 which is the real network of this interface, despite the network command itself being different.
The difference between network 192.168.1.21 0.0.0.0 and 192.168.1.16 0.0.0.15 is obvious: the first way activates the routing protocol on that interface only if the interface has exactly the address 192.168.1.21. If the IP address of the interface changes, it won't be included in the routing protocol anymore. The second option allows the interface to have any IP address in the range of 192.168.1.16 up to 192.168.1.31 and the network from that interface will still be advertised. Note also that the subnet mask of that interface is not compared at all to the wildcard mask specified in the network statement.
IS-IS, OSPF and all IPv6 routing protocols make this issue far more comprehensible: they are activated directly on interfaces and not using the network statement, thereby not suffering from all this mess.
Best regards,
Peter
