EIGRP network unreachable
Goutam Sanyal
Level 4
Level 4
Dear All,
With the attached network diagram, what will be the basic EIGRP configuration to communicate within the two location with unequal cost load balancing.
I have configured but not able to communicate within the inside networks. However from Office 1 router the inside network is completely not accessible but from the Office 2 router only the 172.30.31.0/24 network is accessible.
Both side  ISR 4331 with IOS ver 15.5.
Can anyone please help me.
Goutam
try and turn off auto-summary in your EIGRP on both routers...
I have done all this pos and cos. Not happening.
there is a static default route in the configuration of your Office 1 router, try and disable it.
ip route 0.0.0.0 0.0.0.0 172.30.30.1 name @@@Inside_Network@@@
In addition, when you do a 'show ip eigrp neighbors' on both routers, do the respective routers show up ?
Hi, I cant disable the default route because some of the VSAT networks are connected with the Office-1 router. However I have modified some configuration and EIGRP working, but need to tune the configuration.
