Eigrp on nbma network
feroz syed
Level 3
Level 3
hello,
eigrp running on frame relay topology(multipoint hub and spoke), i have assign loopback address on all three routers eigrp can form neighbor 172.16.124.0 netowrk but in hub router it don't have entry to both spoke loop address and i know split horizon stop  spoke to spoke advertise my point is about hub router has no entry to spoke loop address
here is my config
Router 1
interface Loopback1
ip address 10.1.1.1 255.255.255.0
interface Loopback2
ip address 10.1.2.1 255.255.255.0
interface Loopback3
ip address 10.1.3.1 255.255.255.0
interface FastEthernet0/0
no ip address
shutdown
duplex half
interface Serial1/0
ip address 172.16.124.1 255.255.255.248
encapsulation frame-relay
serial restart-delay 0
frame-relay map ip 172.16.124.3 103 broadcast
frame-relay map ip 172.16.124.2 102 broadcast
no frame-relay inverse-arp
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
router eigrp 25
network 10.0.0.0
network 172.16.124.0 0.0.0.255
auto-summary
ip forward-protocol nd
no ip http server
no ip http secure-server
R1#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
D       172.16.0.0/16 is a summary, 00:05:45, Null0
C       172.16.124.0/29 is directly connected, Serial1/0
     10.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
C       10.1.3.0/24 is directly connected, Loopback3
C       10.1.2.0/24 is directly connected, Loopback2
C       10.1.1.0/24 is directly connected, Loopback1
D       10.0.0.0/8 is a summary, 00:04:34, Null0
Router 2
interface Loopback1
ip address 10.2.1.1 255.255.255.0
interface Loopback2
ip address 10.2.2.1 255.255.255.0
interface Loopback3
ip address 10.2.3.1 255.255.255.0
no ip address
shutdown
duplex half
interface Serial1/0
ip address 172.16.124.2 255.255.255.248
frame-relay map ip 172.16.124.3 201 broadcast
frame-relay map ip 172.16.124.1 201 broadcast
interface Serial1/4
router eigrp 25
network 10.0.0.0
auto-summary
no ip http server
R2#sh ip rou
D       172.16.0.0/16 is a summary, 00:05:35, Null0
C       10.2.1.0/24 is directly connected, Loopback1
C       10.2.2.0/24 is directly connected, Loopback2
D       10.0.0.0/8 is a summary, 00:05:34, Null0
C       10.2.3.0/24 is directly connected, Loopback3
Router 3
interface Loopback1
ip address 10.3.1.1 255.255.255.0
interface Loopback2
ip address 10.3.2.1 255.255.255.0
interface Loopback3
ip address 10.3.3.1 255.255.255.0
no ip address
shutdown
duplex half
interface Serial1/0
ip address 172.16.124.3 255.255.255.248
frame-relay map ip 172.16.124.2 301 broadcast
frame-relay map ip 172.16.124.1 301 broadcast
interface Serial1/1
no ip address
shutdown
interface Serial1/5
no ip address
shutdown
router eigrp 25
network 10.0.0.0
auto-summary
no ip http server
R3#sh ip route
C       10.3.1.0/24 is directly connected, Loopback1
C       10.3.3.0/24 is directly connected, Loopback3
D       10.0.0.0/8 is a summary, 00:05:35, Null0
C       10.3.2.0/24 is directly connected, Loopback2
2 Accepted Solutions
cadet alain
On all routers:
router eigrp 25
no auto
After that you'll see the spokes networks on the hub and the hub networks on the spokes.
You'll also need to configure static frame-relay maps for the other spoke on the spokes if you want to ping the spoke networks without specifying the loopbacks as source interface.
Alain
Auto-Summary in the EIGRP process will summarise your networks as they cross classful bondaries.
So when your 10.x.x.x loopbacks cross a classful boundary (the serial interface 172.16.xx.xx) they become back to there classful summary - 10.0.0.0/8.
cadet alain
On all routers:
router eigrp 25
no auto
Alain
feroz syed
Level 3
Level 3
What is the reason I have to mention no auto summary, it should send tht update to any obe spoke also I have entered wildcard mask. If I do summary like ip route summary eigrp25 can it send tht network update to spoke ?
Sent from Cisco Technical Support Android App
