EIGRP over DMVPN - add route feature no working.
Tammy L. Burley
I stumbled across the add route feature for DMVPN load balancing with EIGRP but can't seem to get the hub to identify or advertise both routes to 10.1.146.0/24.   The EIGRP topology database has 2 routes with the same feasible distance and composite metrics.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_eigrp/configuration/xe-3s/ire-xe-3s-book/ire-add-path.html
interface Tunnel0
ip address 10.1.0.5 255.255.255.0
no ip redirects
ip mtu 1400
no ip split-horizon eigrp 100
ip nhrp authentication NHRPPASS
ip nhrp network-id 1
ip tcp adjust-mss 1360
delay 1000
tunnel source GigabitEthernet0/0.100
tunnel mode gre multipoint
tunnel key 150
tunnel protection ipsec profile DMVPN_PROFILE
router eigrp MULTI-AF
address-family ipv4 unicast autonomous-system 100
af-interface default
authentication key-chain MD5_KEYS
exit-af-interface
af-interface Tunnel0
no next-hop-self
add-path 2
no split-horizon
exit-af-interface
topology base
exit-af-topology
neighbor 10.1.45.4 GigabitEthernet0/0.45
network 10.0.0.0
network 150.1.0.0
exit-address-family
R5#sho ip eig top 10.1.146.0/24
EIGRP-IPv4 VR(MULTI-AF) Topology Entry for AS(100)/ID(150.1.5.5) for 10.1.146.0/24
State is Passive, Query origin flag is 1, 2 Successor(s), FD is 7209615360, RIB is 56325120
Descriptor Blocks:
10.1.0.1 (Tunnel0), from 10.1.0.1, Send flag is 0x0
Composite metric is (7209615360/1310720), route is Internal
Vector metric:
Minimum bandwidth is 100 Kbit
Total delay is 10010000000 picoseconds
Reliability is 255/255
Load is 2/255
Minimum MTU is 1400
Hop count is 1
Originating router is 150.1.1.1
ECMP Mode: Advertise by default
10.1.0.4 (Tunnel0), from 10.1.0.4, Send flag is 0x0
Vector metric:
Load is 2/255
Minimum MTU is 1400
Hop count is 1
Originating router is 150.1.4.4
ECMP Mode: Advertise out Tunnel0
R5(config-router-af-interface)#do sho ip route | in 10.1.146
D 10.1.146.0/24 [90/56325120] via 10.1.0.4, 00:00:54, Tunnel0Screen Shot 2021-02-11 at 5.48.25 PM.png
R3#sho ip route | in 10.1.146
D 10.1.146.0/24 [90/81925120] via 10.1.0.4, 00:19:17, Tunnel0
interface Tunnel0
ip address 10.1.0.3 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map 10.1.0.5 169.254.100.5
ip nhrp map multicast 169.254.100.5
ip nhrp holdtime 300
ip nhrp nhs 10.1.0.5
tunnel key 150
6 Replies 6
One tunnel in spoke so one route
Are you saying that this nerd knob requires multiple tunnels to load balance traffic to 10.1.146.0 between R1 and R4?  I don't read the solutions guide that way.   Not sure it's best practice or common to have multiple dmvpn tunnels to the same NBMA address endpoints?
Dual hub serve same subnet,
we config dual tunnel, one with each hub router and we config delay to make spoke1 prefer one tunnel than other.
TJ-20933766
If tunnels are established to both R1 and R4, I don't see why R5 wouldn't have two routes to 10.1.146.0/24. Can you confirm that tunnels to both R1 and R4 are up and that you show R5 to be EIGRP neighbors with R1 & R4?
georgehewittuk1
-Is R3 eigrp process/topology getting both routes?
-Is tunnel pingable to r1,r4 from r3.
-Observe show ip eigrp events?
Config looks fine
Tammy L. Burley
I lost track of this problem.  It was a lab.  Thank you for your replies
